xvilar
Looking for a router with some reqs
Mon Dec 21, 2020 3:48 pm
I'm looking for a router to put aside my ONT's internet company fiber router+ont, and I would like to have:
- latest wifi specifications, protocols and improvements
- Multi VPN client (I think it's called split tunneling) to be able to select which local network device connects with which differents VPN services
- Capable of act as a VPN server also
- DHCP + Local DNS (like I'm doing right now with DNSMASQ in a linux server)
I'v been told about Mikrotik Hap AC3 ... what do you think? differences with HAP Ac?
Thanx!
mkx
Re: Looking for a router with some reqs  [SOLVED]
Thu Dec 24, 2020 8:17 pm
I'm afraid that your requirement for latest wifi you're effectively ruling out Mikrotik for now (it should improve for high-end wireless devices with ROS v7). The last item (DHCP + local DNS) is doable with some scripting, doesn't work out of the box. The rest is more or less fine with Mikrotik (if requirements regarding VPN are not too strict, ROS' support for openvpn for example is less than complete).
BR,
Metod
xvilar
Thu Dec 24, 2020 8:21 pm
Thanx @mkx !
Users browsing this forum: uldise and 39 guests
