dhwzh
seek help
Wed Dec 23, 2020 11:48 am
Software upgrade makes the equipment work unstable. Now I want to upgrade or downgrade other versions, but I can't finish it. Uploading multiple other versions doesn't work. I don't know the problem there.
Please ask if there is any other way, thank you.
My hardware is rb2011uas
erlinden
Long time Member
Long time Member
Re: seek help
Wed Dec 23, 2020 12:21 pm
If you run into problems, you might want:
  1. export your configuration (/export file=anythingyoulike)
  2. Save file to local computer
  3. Reset RB to defaults
  4. Upgrade
  5. upload config file
  6. import your configuration (/import file=anythingyoulike)
Do you get any errors (check in the log)?
First the problem, then the solution
dhwzh
Re: seek help
Wed Dec 23, 2020 12:44 pm
It's been tried. It can't solve the problem
It is estimated that it was caused by a problem when upgrading the system
  4. Upgrade
erlinden
Long time Member
Long time Member
Re: seek help
Wed Dec 23, 2020 1:22 pm
What is the current state of the RB?
Is the device running?
Are you aware of using Netinstall (as last resort)?
https://wiki.mikrotik.com/wiki/Manual:Netinstall
dhwzh
Re: seek help
Thu Dec 24, 2020 3:16 am
Can run, often disconnected and restart
Problems after the last system upgrade
dhwzh
Re: seek help
Thu Dec 24, 2020 9:55 am
Attempt to install failed to detect a device in etherboot mode
It is found that the ether1 interface is unable to log in to winbox, but it works normally as a WAN port
Users browsing this forum: velk1001 and 27 guests
