makaron
Micro SIM card stuck in LHGG LTE6 kit
Thu Jan 07, 2021 8:52 pm
I wanted to test four different ISPs with the LHGG LTE6 kit to check which one provides the fastest bandwith in my area.
The first micro SIM card I used was inserted and ejected with no difficulty, but the second one got stuck. I've been trying to pull it out with a SIM card eject tool but no succes, so I decided to check if anyone had the same problem. While I was browsing the Internet for a solution, my reckless brother came up with "a brilliant idea" of using a small flat screwdriver and it only worsened the situation.
Is there any possibility of removing the SIM card?
RogerWilco
Re: Micro SIM card stuck in LHGG LTE6 kit
Sat Jan 09, 2021 12:43 am
Take the cover off and take out the PCB, you should be able to work it out with a fine screwdriver or skewer. Same thing happened to me.
Users browsing this forum: velk1001 and 39 guests
