SpartanX
Purchase advice: hAP ac2 vs RB450Gx4 vs RB850Gx2
Fri Jan 08, 2021 6:01 am
I currently use an RB850Gx2, had it for years and I'm starting to think I should have a spare (or replace and keep the old 850 as the spare). I know the 850 is now discontinued but they can be had used for about the same price as a new hAP ac2.
Also, I want to split off all the IoT stuff (smart plugs, Echos etc) onto a VLAN because it makes me nervous having them on my LAN. I could do with another WiFi AP too (needs to support VLANs and multiple SSIDs) although I might get away with using what I already have.
So, I'm looking at the routers in the title. Any comments on which would be most suitable, if any are overkill or whatever would be appreciated. Budget is of course small, as always, but I can just about afford the RB850Gx4 if that was 'needed'. The hAP AC2 is looking the best bet to me so far though as it also ticks the AP box (assuming it can do multiple VLANs/SSIDs - surely it can but I'm off to read the manual now.)
This is what I do/have/want to achieve:
  • Home user, heavy use, frequently saturate my internet connection. A bit of a networking geek and occasionally run external services, but only occasionally.
  • Have two storage NASs; three HiDef IP security cameras on constant record to a third NAS; occasional Netflix; many PCs and other devices but there's only my wife and me live here so most are not on all the time; occasional offsite connection in via VPN to access my NASs and virtualized HP server.
  • 80Mbps/20Mbps internet connection (FTTC, modem in bridge mode; the 850 does the PPPoE etc.)
  • /29 routed IPv4 subnet. The 850 firewalls/routes some of that off into a DMZ, static NAT for a PC and a server and PAT for the rest.
  • HE IPv6 tunnel terminating at the 850 (my ISP is not IPv6 yet).
  • Cisco L3 gigabit main switch.
  • Three VLANs: Main LAN (wired and WiFi), DMZ, IoT WiFi LAN (to be added, replacing my Cisco lab VLAN which is going).
  • Firewall to route/allow connections from Main VLAN to IoT but not allow initiating a connection from IoT to Main.
  • The VLANs are currently done on the Cisco switch; the 850 is not VLAN aware but simply connects each subnet with one socket to the switch.
  • Two Wifi VLANs/SSIDs on each band (Main Lan and IoT).
  • I would like a switch chip in the router capable of hardware VLAN offload, in case I want to configure my VLANs on the router itself with both access and trunk ports.
  • Currently I have one port on the router (in a bridge with the Main LAN port to the Cisco switch) wired to my 'main' PC, the intention being that everything else on the LAN can fail but as long as my modem and router are working, I still have a working PC. That PC is often involved in large file transfers so must have wire Gb speed through the router to the rest of the LAN.
jebz
Re: Purchase advice: hAP ac2 vs RB450Gx4 vs RB850Gx2  [SOLVED]
Fri Jan 08, 2021 11:02 am
In your situation I'd get the hAP ac2. The RB450Gx4 and the hAP ac2 are near equal for your tasks but the hAP ac2 has dual band wireless AC. If you ran Dude you may be swayed to the RB450Gx4 with more memory and SD card support.
Users browsing this forum: mada3k and 49 guests
