JGA
HEX S RB760iGS - temperature.
Mon Jan 25, 2021 6:33 pm
Hi guys!
I recently bought a HEX S Routerboard RB760iGS for my home network.
Everything works perfectly, but there is one thing that bothers me - it is the temperature.
The router is installed on my garage wall. Currently, the air temperature inside my garage is 27 Celsius (winter in Florida).
The router itself warms up to 42-45 degrees.
In the summer the air temperature in my garage will increase by about 10 degrees, consequently the router will warm up to 55-60 degrees.
Do you think it is critical for this particular model and I need to take care of it, or I should not worry about it?
Thank you in advance for your opinions and suggestions.
Elans
Re: HEX S RB760iGS - temperature.
Tue Jan 26, 2021 9:12 am
That is normal temperature.
Tested ambient temperature for this device: -40°C to 70°C.
JGA
Wed Jan 27, 2021 7:29 am
Elans, thank you for your response.
I read this particular spec before purchasing - how much time does such kind of tests usually take (hours/weeks/months)?
Thank you again.
Users browsing this forum: No registered users and 59 guests
