sealouiw
cAP ac - a few questions
Sun Jan 31, 2021 11:17 am
1. I am about to buy a MikroTik RouterBOARD cAP ac and have a question about the LED configuration. I've read that you can turn them off through software, but I've also read that they turn on automatically when you turn the device off and on again. Is it possible to keep the LED configuration on device restart?
Edit: The LED configuration does persist across reboots. A single press of the center button is enough to permanently disable all LEDs. Nice!
2. Is it possible to put the device into some sort of deep sleep via software?
krafg
Forum Veteran
Forum Veteran
Re: cAP ac - a few questions  [SOLVED]
Thu Feb 04, 2021 5:58 am
System > Shutdown. But you will need to reconnect AC plug or PoE.
Regards.
If you want to know my network, you can find it here.
Telegram: @krafgrgi
quackyo
Thu Feb 04, 2021 11:38 am
Or you can disable "most" things on it, like disable WLAN from a scheduler,
sealouiw
Fri Feb 05, 2021 7:32 pm
Would be great if there was some kind of Wake-on-LAN feature.
I tried that, and the lowest power consumption I was able to achieve so far is 3.4 W.
Users browsing this forum: mod3m and 29 guests
