kwagga
RBMQS - Terrible Throughput
Tue Feb 09, 2021 9:26 am
Good Day All
I need some advice regarding the MQS device - We are getting very very bad throughput while doing diagnostics and speed tests - I know the unit has a tiny processor, and I'm not expecting 100mbps throughput, but not even getting 10mbps - surely something isn't right?
Changing bands, frequencies and protocols doesn't help at all. Also disabled SNMP, DHCP, etc in case it was taxing the tiny CPU.
Product: https://mikrotik.com/product/mqs
Line Actual Speed:
Speed test through MQS connected from WAN ETH to WLAN:
Config Pages:
With cable connected, it showed full duplex 100mbps:
Any advise would be greatly appreciated! :)
Thanks,
Werner
Werner van Heerden
wernergvh[@]gmail.com
HNDip(IS:Network Engineering) - MTCNA - MTCWE - CCENT - MCITP - MCTS
Rudolfs
Re: RBMQS - Terrible Throughput
Tue Feb 09, 2021 11:48 am
MQS's main purpose is to manage other devices and to do their maintenance if needed. High throughput should not be expected, but in your case, I recommend try changing the band from b/g to b/g/n.
Users browsing this forum: No registered users and 43 guests
