tdussa
Netinstall from a ROS device?
Sat Feb 13, 2021 10:48 am
I've been wondering and searching the net and this forum about this. Maybe I am too blind to find information on this, but maybe there is no info.
Is it possible to run the `netinstall` server component on a ROS device? As in, use an MT router to reinstall a broken AP? All I can find is a Windows and, as I have found out very recently to my great relief, a Linux version of `netinstall`, but is there a way to do that from ROS?
Cheers,
Toby.
mkx
Re: Netinstall from a ROS device?
Sat Feb 13, 2021 11:31 am
No, there's no netinstall tool for ROS.
BR,
Metod
mada3k
Sat Feb 13, 2021 11:49 am
It should be possible with a remote-netinstall over a EoIP/VPLS tunnel, with a Linux/Windows host on the other side?
CCR/CRS/hEX/wAP • Ansible • NetXMS
mkx
Sat Feb 13, 2021 3:50 pm
Given fragility of netinstall process which is likely to fail even with direct UTP connection between netinstall server and routerboard device ... it would surprise me if this would work. I'm not saying it's not possible though ...
BR,
Metod
tdussa
Sat Feb 13, 2021 3:59 pm
Bummer. That would be a really nice feature to have.
Thanks for your quick reply!
Cheers,
Toby.
tdussa
Sat Feb 13, 2021 4:00 pm
Hm... :) Interesting idea. If I find the time, I'll look into that.
THX!
Cheers,
Toby.
Users browsing this forum: dksoft and 49 guests
