Mikhalich
Which ROS devices do you expect the most?
Sun Feb 14, 2021 3:44 pm
I apologize if not the first who write about this.
From myself I will say that I really look forward to:
1. RB4011 (10х1G ether ports & sfp) with USB, microsd and supports LTE6 module.
2. Microcircuit RouterBOARD on ARM platform, like in RBD23UGS-5HPacD2HnD supports 802.3af/at PoE in.
Maybe the representatives of Mikrotik will sound not very distant plans for the development of ROS hardware?
Cablenut9
Re: Which ROS devices do you expect the most?
Sun Feb 14, 2021 4:19 pm
Anything with 802.11ac wave 2 or 802.11ax, maybe a cAP ax?
mada3k
Sun Feb 14, 2021 6:49 pm
More port-versatility and telecom-format
viewtopic.php?f=3&t=172301
CCR/CRS/hEX/wAP • Ansible • NetXMS
pcunite
Sun Feb 14, 2021 10:40 pm
A CRS326-24G with 4 SFP+ ports. A 16 port ethernet short depth version of the CRS328-24P.
r00t
Sun Feb 14, 2021 11:04 pm
60GHz radios with SFP slots - this should have happened long time ago, even if it's just SFP and not SFP+. Running fiber is cheaper then ever before and solves EMI issues.
WIFI6 - Mikrotik is late to the game and competition is never sleeping
And in general anything that doesn't have flapping ports (just don't use the problematic switch chipsets ever again), stupid hardware limitations (include all available interfaces CPU provides, if it does have USB, at least put header on the PCB or extra miniPCIe slot) and more routers with SFP+ slots (and support passive DAC cables, don't do the 4011 thing ever again).
What I really DON'T want to ever see from Mikrotik are devices with 16MB of flash and limited ram, now that it's clear ROS 7 with wifi2 package will not run on these. It's one thing to announce it will not be compatible with older products... but if any device is announced with these limited specs now, it will be D.O.A.
Phillip
Mon Feb 15, 2021 3:31 am
I would have to agree with what was already said. I am planning on buying a RB4011, but I think MT missed on it. It should of had 10Gb copper ports instead of 1Gb ports. I also think they shot them self's in the foot with the WAP Ac upgrades knowing that they are going to release Router Os 7 with the WiFi 2 software upgrade.
What I would like to see them release....
1) Hex with a SFP+ and 5 1Gb ports,
2) WAP/CAP with a 4x4 matrix, 128MB Flash, 256 or 512 DDR, 1.2GHz ARM, 1Gb or 2.5Gb ethernet port.
3) CRS30X with 5 10Gb copper ports and one SFP+ port. (RB260 Type of switch)
Navegador
Mon Feb 15, 2021 6:02 am
That's easy - SXT R (LTE) with gigabit port(s).
And maybe M.2 slots in all Mikrotik LTE compatible products.
RogerWilco
Tue Feb 16, 2021 12:52 am
A SXT LTE device for lower bands.
allstarcomps
Tue Feb 16, 2021 6:55 am
POE devices with powerful processors
Power box Pros or Omnitik Poe's with Arm CPUs.
I don't think that's much to ask for.
olivier2831
Tue Feb 16, 2021 9:07 am
+1 or alternatively, CSS610-8P-2S+ which was announced in MUM 2019 Europe
mAP or mAP Lite with 5GHz radio
A 4-ports device with Ethernet bypass
ech1965
Sat Feb 20, 2021 8:54 am
My whish
RB4011 without the switches: one sfp+ and 2x 2.5 GBE ports TRUNK WAN DMZ
ste
Sat Feb 20, 2021 9:21 am
A netpower 16P with a fast CPU.
Łukasz
Mon Feb 22, 2021 3:48 pm
+1 for netpower 16P with better CPU.
SGtv
Mon Feb 22, 2021 10:57 pm
When we have the CRS318-16P-2S+OUT and CRS328-24P-4S+RM could we not also have something like CRS314-12P-2S+IN or even better CRS314-8P-4P+-2S+IN
As the board already seems to exist
CRS308-4P-2P+-2S+OUT
CRS310-8P-2S+IN
CRS314-12P-2S+IN
CRS318-16P-2S+IN
Any of these with rack ears would be good and even better if the smallest one could be powered by POE in which could be put in an attic and take a couple of new wifi6 ax access points and run a few CCTV cameras (seems to be working for Unifi).
atifivacy
Wed Feb 24, 2021 4:31 pm
Anything with wave 2 or 802.11ax of 802.11ac, maybe a cAP ax.
SiB
Wed Feb 24, 2021 11:01 pm
CCR with 48GbE
LTE devices with m.2 slot and hearpipe...
P.S. Title is bad, right will be "Which RouterBoard devices do you expect the most?"
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | Buy me a caffe
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
pcunite
Wed Mar 03, 2021 8:50 pm
I want this.
Users browsing this forum: Toxic and 50 guests
