gasola
LtAP LTE6 Modem
Sat May 29, 2021 3:10 pm
Hello
Please I have the LtAP LTE6. I just installed Sierra wireless MC 7710 modem into the second pcie expansion slot,but the modem is not showing up in winbox.
Please is there something that I need to do?
krafg
Re: LtAP LTE6 Modem
Sat May 29, 2021 5:37 pm
Use this command:
/system routerboard usb set type=mini-PCIe
More info about LtAP here.
Regards.
gasola
Re: LtAP LTE6 Modem
Sat May 29, 2021 5:48 pm
Please is there a way to do this in winbox since am very familiar with that and also new to mikrotik?
If that is not possible then I will copy and past the command you just told me
krafg
Re: LtAP LTE6 Modem
Sat May 29, 2021 10:00 pm
System -> RouterBOARD -> USB
Regards.
gasola
Re: LtAP LTE6 Modem
Sat May 29, 2021 11:25 pm
You are the man.I have been able to do it now.May God bless you.Now the am try to combine bandwidth from the two (2) lte modems.ie lte1 & lte2.
Or at least get them to work at the same time like even if the bandwidth can not be bonded.I hope someone can take me through that via winbox. Or send me a script.
Thank you so much
Users browsing this forum: Smokeshow and 12 guests
