Cablenut9
Long time Member
Long time Member
wAP 60Gx3 bandwidth
Thu Jul 15, 2021 4:40 pm
How much bandwidth does the wAP 60Gx3 have between the three phase-array antennas? I'm wanting to make a setup where lots of data will be sent to and from these antennas/radios but in the block diagram, there's no speed listed for the link between the CPU and the 60GHz radio. This likely means it's a DMA setup but I'm not sure what kind of RAM it's using.
rextended
Re: wAP 60Gx3 bandwidth
Thu Jul 15, 2021 5:17 pm
If you do only "internal L2 routing" between the clients and the ap, you can really reach the gigabit sum,
but if your AP must do also NAT, firewall, etc. do not expect more than 150Mbps for station...
Cablenut9
Long time Member
Long time Member
Thu Jul 15, 2021 5:44 pm
I'm not using the gigabit port at all, but rather L3 routing between stations connected to the wAP itself.
Users browsing this forum: No registered users and 76 guests
