yusempron
RB333 throughput very low
Tue Aug 28, 2007 6:32 am
I tested RB333 with RouterOS 3.0rc3. eth1 and eth2 setup bridge mode with 64k packet size.
setup bridge use-ip-firewall = no
throughput = 37.1kpps
setup bridge use-ip-firewall = yes
throughput = 14.3kpps
maybe enable NAT throughput will be lower!!
How to improve throughput????
macgaiver
Re: RB333 throughput very low
Wed Aug 29, 2007 12:57 pm
I got a heart attack first time when I read it!!!!
Don't do that again!
Clarification:
kpps = thousand packet per second
normis
Wed Aug 29, 2007 1:07 pm
Configuration:
only system, advanced-tools, routerboard package enabled
/ip firewall connection tracing disabled
/interface bridge settings use-ip-firewall=no
/ip neighbor discovery disabled
Our results are:
bridging: 81700 pps = 81,7 kpps
routing: 41000 pps = 41 kpps
also make sure the packets (test) is generated by a powerful machine, not every PC can generate so many packets
yusempron
Thu Aug 30, 2007 1:58 am
Configuration:
Our results are:
So what about enable NAT rule?
macgaiver
Thu Aug 30, 2007 8:55 am
NAT will require to enable connection tracking - so it will be slower
tanxw998
Thu Aug 30, 2007 12:52 pm
I think RB532 RB33 and the same performance
normis
Thu Aug 30, 2007 2:04 pm
no way. tests indicate that RB333 is ~ 2-3 times faster than RB532
tanxw998
Thu Aug 30, 2007 2:24 pm
rb333 test NAT when the packet size is 64 bit
throughput only 15kpps
i thinks is too slow
normis
Thu Aug 30, 2007 2:53 pm
my test is 81000pps, on same conditions. so your test is bad ;)
firebat
Fri Aug 31, 2007 5:39 am
Normis:
Does Miktrotik have throughput performance measurements for each of its routerboards with different packet sizes? It would be nice to have a table so everyone can reference it (obvioulsy caveated with lab and test scenario information).
normis
Fri Aug 31, 2007 10:19 am
yes we do. we might publish it in near future. an old one actually is already on the routerboard site:
http://routerboard.com/pdf/results_18may2007.pdf
Users browsing this forum: No registered users and 35 guests
