MUM Europe 2020
dslrh
RB 532 fixed Frequence issue?
Tue Nov 27, 2007 10:02 am
Hi Forum,
i have the following configuration:
1x RB 532
2x R52 Mini PCI (1x AP, 1x client)
1x H&S 23 dBi antenna
1x H&S 19 dBi antenna
routerOS 2.9.49 (5GHz regulation Domain Germany - DFS an)
Following issue:
scanning on the client interface for reachable networks discovers all networks on frequency of 5180 MHz - regardless which frequence is setup on the other side. connecting to a wlan is not possible.
Activating the other interface as AP on e.g. 5700MHz - the client interface also "sees" it on 5180 MHz.
Also another Routerboard a few 100 meters away "sees" this AP on 5180 and not on the setup 5700 MHz.
Also for this: connecting is not possible.
Is this a hardware problem or a known rouiterOS issue which can be fixed easily?
anybody any idea?
Regards
Heiko
ste
Re: RB 532 fixed Frequence issue?
Tue Nov 27, 2007 3:46 pm
Hi Forum,
1x RB 532
Following issue:
anybody any idea?
Regards
Heiko
May be a configuration error. Do you use dfs without a scan list?
5180 is then the first frequency to use. And as it's a low power
frequency it gives real bad connections.
Stefan
heiko_s
Tue Nov 27, 2007 5:36 pm
Stefan
Thanks for the hint.
Does dfs override the set up primery frequency ?
Regards
Heiko
ste
Wed Nov 28, 2007 12:12 pm
Stefan
Regards
Heiko
Yes. A single setup frequency does not make sense for dfs.
To see the real used frequency with dfs you've to use
terminal: interface-wireless-wlanX-monitor-once. winbox always
shows the setup frequence.
So if you want to use the full german outdoor frequencies you have
to enter them all to the scanlist.
Stefan
Users browsing this forum: mariusbrouwe and 18 guests
