Gerard
Trainer
Trainer
RB411/411R Extra LED's ??
Sat Dec 08, 2007 6:28 am
I was just looking at the RB411 in the newsletter and I noticed some additional led's on the lower right of the board.. Since I already see the normal led's on the board I'm REALLY REALLY hoping those are signal strength lights..
Can someone from Mikrotik please let us know what they are going to be used for..
Thanks!
-Gerard
Certified Mikrotik Trainer
uldis
Re: RB411/411R Extra LED's ??
Mon Dec 10, 2007 10:46 am
first led indicates the NAND memory access.
About ohter leds - you will be able to use it for signal strenght of for some other advanced features.
Currently the signal strenght monitoring is not added in the RouterOS yes, but we will make it soon.
If you have some other ideas where to use those leds, you can post the ideas here.
Stanislav Hrncir
Mon Dec 10, 2007 12:14 pm
what is "whiteLIGHTNING" near buzzer ? :)
Is realy idea adding non "blink" mode for this led eg. ON / OFF ? My idea is unsoldering this leds and mount solid state relay, because i need some I/O output...
normis
Mon Dec 10, 2007 12:49 pm
have you not noticed that all boards have some kind of nickname on them? Triple-Shot, Crossroads, miniRouter, trifecta etc.
InoX
Mon Dec 10, 2007 6:43 pm
Will be a replace and for RB133? Like 411 but with 3xminiPCI?
normis
Tue Dec 11, 2007 9:01 am
eventually
jorj
Tue Dec 11, 2007 11:00 am
It would be nice if you could make some choice for the user to make the leds indicate:
- signal strenght, or
- ccq for the wireless link or some other kind of link quality indicator, or
- % cpu used, or
- % memory free
kbyrd
Thu Mar 06, 2008 12:07 am
The one next to ethernet port you can make stay on or off
:led user-led yes(or no)
Is there a command for the other led's yet that im missing? noticed led1-5 gives "not implemented yet" msg.
CarulloS
Fri Mar 07, 2008 5:57 am
I really don't see the usefulness of making the lights for signal or much anything else except relay type outputs, I don't have a single configuration of radio / enclosure that I can aim and operate while looking at the leds.
Can you guys really aim antennas while looking at the leds??
Scott
Gerard
Trainer
Trainer
Fri Mar 07, 2008 6:01 am
As soon as they add this I'll start putting a plexiglass window in the back/bottom of the enclosure antenna's I'm using so that my installers can see the alignment LED's..
-Gerard
dastring
Tue Apr 14, 2009 5:59 am
Is there a way to possibly use some scripts to light up those LEDs for alignment purposes? Signal strength or quality of link? That would be immensely useful for my uses....
alexspils
Wed Apr 15, 2009 9:48 am
yes there is a way.it is described in wiki
saintofinternet
Forum Veteran
Forum Veteran
Wed Jan 12, 2011 12:52 pm
-Gerard
have you done the plexiglass installation??
by professionals, for professionals....
Don't forget to give KARMA!!!
Users browsing this forum: Google Adsense [Bot], stelios_g and 22 guests
