mazout
Alix3c2 and MikroTik
Thu Dec 27, 2007 7:42 pm
I have bought http://www.pcengines.ch/alix3c2.htm but i could NOT install Mikrotik. I have install MT in the Compact Flash but it could NOT boot from the CF. Is there any support for alix3c2 from MT?
Any ideas how can i use Mikrotik in alix3c2??? Please help....!!!!!!!!!!!!!!
normis
Re: Alix3c2 and MikroTik
Fri Dec 28, 2007 9:47 am
contact the manufacturer. we haven't tested this device.
mazout
Fri Dec 28, 2007 2:52 pm
I have just contacted with manufacturer and he told me to try a different compact flash because mikrotik i very picky about CFs . Do you know what type of cf to use?
thanks
normis
Fri Dec 28, 2007 4:58 pm
Not sure if that will help. Strange suggestion. Anyway use good brand, sandisk or lexar or similar.
nowires
Sun Dec 30, 2007 8:09 pm
First, you must use x86 version. Second, try with 256MB Kingston CF.
I had many problems with 512+ MB from Trascend in my WRAPs boards.
mazout
Thu Jan 03, 2008 1:56 am
I have tried without any result 1Gb kingston 512 sandisk and 128 noname. With Kingstone and sandisk it starts to boot and it writes "ok ready" but after that nothing. It suppose that after "ok ready" MIKTOTIK login will appear but unfortunately nothing happens.
Any others ideas???
cmit
Tue Jan 08, 2008 3:16 pm
Do you have the latest BIOS on your ALIX board?
There seem to be some boot/install issues with older BIOS versions.
Get the current one from the manufacturer website...
Best regards,
Christian Meis
normis
Tue Jan 08, 2008 3:20 pm
I didn't say that they fixed it. No idea
mazout
Thu Jan 10, 2008 1:05 pm
I have updated with the last firmware but i have the same problem. Now I have ordered a kingston 256 compact flash. Last try.........
Users browsing this forum: No registered users and 76 guests
