Gerard
Trainer
Trainer
RB411 specs released
Fri Dec 28, 2007 2:23 am
Mikrotik announced the specifications for the RB411 to distributors today. I can't wait to get my hands on these babies. Same size, standoffs, and price as the RB133c but with MUCH more power.
-Gerard
CPU Atheros AR7130 300MHz network processor
Memory 32MB DDR SDRAM onboard memory
Boot loader RouterBOOT
Data storage 64MB onboard NAND memory chip
Ethernet One 10/100 Mbit/s Fast Ethernet port with Auto-MDI/X
miniPCI One MiniPCI Type IIIA/IIIB slot
Extras Reset switch, Speaker
Serial port One DB9 RS232C asynchronous serial port
LEDs Power, NAND activity, 5 user LEDs
Power options Power over Ethernet: 12..28V DC (except power over
datalines). Power jack: 12..28V DC
Dimensions 10.5 cm x 10.5 cm (4.13 in x 4.13 in) Weight: 82 g (2.9 oz)
Power consumption ~3W without extension cards, maximum – 12 W
Operating System MikroTik RouterOS v3, Level3 license
Certified Mikrotik Trainer
Gerard
Trainer
Trainer
Re: RB411 specs released
Wed Jan 09, 2008 7:21 pm
I just got my hands on some RB411's and I have to say I'm REALLY impressed..
31-32 either way send or receive and 18.5 both ways.
2.4 g only, nstream checked, polling checked, disable csma unchecked, framer policy=best fit
23-24 either way send or receive and 13.5 both days..
2.4 g only, nstream disabled
-Gerard
InoX
Thu Jan 10, 2008 1:09 am
It's for client...no need for that speed usually.
Gerard
Trainer
Trainer
Thu Jan 10, 2008 4:15 am
That's why I'm impressed.. This $59 CPE has some power behind it..
Just because it's intended for CPE doesn't mean it should be underpowered..
-Gerard
roc-noc.com
Forum Veteran
Forum Veteran
Thu Jan 10, 2008 4:23 am
Not all access points need to support 100 cpe. With a level4 license this would make a nice microPOP AP.
Also good for low cost PtP links.
Early shipments come with level 4. Later volume production level 3.
The down side is that it is a new processor and so only version 3 support and probably comes with bugs.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
a-l-i-e-n
Fri Jan 11, 2008 3:30 pm
what will be 411R ?
on the board is RouterBOARD 411/411R mark like on RouterBoard 133/133c
so what will be RB411R like?
Gerard
Trainer
Trainer
Fri Jan 11, 2008 4:05 pm
The RB411 appears to have a wireless radio built into it although the components aren't populated on the board at this time. I'm guessing the RB411R has the built in radio card. I'm not sure if we'll ever see the RB411R though since they announced the crossroads board yesterday which has a built in radio too..
-Gerard
cmit
Fri Jan 11, 2008 4:59 pm
Yes, but the Crossroads only has 2.4 GHz on it. Having 5 GHz onboard COULD be an interesting option sometimes. We'll see... ;-)
Best regards,
Christian Meis
phendry
Sat May 17, 2008 9:48 pm
I see from the routerboard website that a couple of these should outperform both the old RB532 and also the RB333. Test sheet does say tests performed through ethernet but RB411 only has 1 ethernet port so not sure how they verified this. Has anyone compared a couple of cheap RB411's with the old "high performance" RB333's?
ghmorris
Sat May 17, 2008 9:59 pm
A base 411 with the introductory level 4 license is just about the ultimate in current MT backhaul radios IMHO. I'm not sure you are going to go any faster with a more expensive RB so long as you are only using one radio card.
One card, one box, super low price. XR5s run great on a 411. It will max out a Turbo channel at 75Mb +/- (if you are lucky enough to find the free spectum to run Turbo).
We have excellent results using routing with conn track turned off. Very pleased with the first batch, another sixty-five are on the way.
George
phendry
Sun May 18, 2008 12:40 pm
Exactly what I was thinking as the RB600's are huge especially when compared to the 411's. With NStreme enabled, what sort of real word figures are people seeing and does the extra memory in the 411a make a difference?
roc-noc.com
Forum Veteran
Forum Veteran
Sun May 18, 2008 8:37 pm
I asked Janis Megis that question a few days ago at Chicago MUM and he said that they tested it using "router on a stick" which means vlans terminating on a single port.
Tom
888-762-5662
ghmorris
Sun May 18, 2008 10:33 pm
A very efficient way to operate, we break out VLANs into 24 port managed switches quite often. It would be even nicer if the 433AH had gig ports intead of 10/100, but I suppose that would eat into sales of the RB1000.
George
Users browsing this forum: No registered users and 22 guests
