InoX
CrossRoads
Sat Mar 22, 2008 11:22 pm
What is the wlan power?
In Brochure says 26dBm and in Users Manual says "with 1W maximum output power" . The difference is BIG.
So witch one is it?
InoX
Re: CrossRoads
Sun Mar 23, 2008 10:11 pm
Hello?! What are you selling people?
normis
Re: CrossRoads
Tue Mar 25, 2008 8:22 am
to be compliant with FCC it had to be locked down to 26dB
promind
Re: CrossRoads
Tue Mar 25, 2008 8:59 am
Sorry for writing here but all I have to write is about crossroads so I'll use this topic:
I recently baught rb crossroads and it came with 2.9.47...I upgraded it to 3.6 and it died...
serial connection says jumping to kernel code and after 3/4 minutes it reboots/the funny thing is that I must reset it from the botton everytime when I want to launch it otherwise it does not want to come alive/.
I've erased nand and I've been trying 2 days to put ros-3.5 on it with no luck.
Here is what happens:
yri
Re: CrossRoads
Tue Mar 25, 2008 9:35 am
I have the same with crossroads now :( :( :(
Need solutione badly
solved BY
DO NT USE ver 3.6 NET INSTALL ITS BUGED and routeros 3.6 the same!!! older versione solv all problems
uldis
Re: CrossRoads
Tue Mar 25, 2008 12:19 pm
Please use v3.4 which works fine on Crossroads.
you can download it from download page, there is also v3.4 netinstall whichs works with the crossroads. We will try to fix the problems with new version and the RB Crossorads.
http://www.mikrotik.com/download.html
0ldman
Re: CrossRoads
Mon Mar 31, 2008 12:58 am
How can I recover a crossroads board that won't boot up now?
Upgrade over serial says error limit exceeded in about 3 seconds. Upgrade over ethernet says invalid upgrade file id.
uldis
Re: CrossRoads
Mon Mar 31, 2008 9:45 am
how did you tried to upgrade the board?
Please use v3.4 netinstall and v3.4 packages for installing crossroad.
0ldman
Re: CrossRoads
Mon Mar 31, 2008 4:28 pm
Netinstall doesn't show any device. The Crossroads pulls an IP, then says invalid file ID. Never shows up in Netinstall.
Nothing shows up in Winbox, nothing shows up in Netinstall, Crossroads plugged directly to the laptop with a crossover cable. Crossroads pulls an IP, but refuses to update. Is there something I'm missing in Netinstall? I have chosen my directory where I have v3.3. Does it have to be 3.4?
0ldman
Re: CrossRoads
Mon Mar 31, 2008 5:27 pm
Tried 3.4, same problem, with Netinstall v3.4 or 3.6.
0ldman
Re: CrossRoads
Mon Mar 31, 2008 5:58 pm
Ok, got it booting from ethernet, transfer ok, setting up elf image ok, jumping to kernel code and it just sits there.
0ldman
Re: CrossRoads
Mon Mar 31, 2008 7:28 pm
Got it going.
Using Netinstall 3.4 and firmware ROS 3.3, boot from ethernet, install, tada.
Users browsing this forum: No registered users and 53 guests
