phendry
External Input via Serial
Wed May 21, 2008 3:27 pm
Does anyone know if it is possible to use the serial port within RouterOS for generating alarms? We currently Use some high grade linux based cameras which have a serial interface for connecting open relay device such as door entry systems. I know there are devices out there that can easily do this but can't see any technical reason why it couldn't be done within the CPE as long as the software supported it.
jcollery
Re: External Input via Serial
Fri Jun 20, 2008 1:20 pm
Anybody with information on how to do this, it would have many applications.
Thanks and regards,
Justin
jcollery
Fri Jun 20, 2008 1:31 pm
Answered my own question, RTFM! :)
Disable the console with
system console set 0 disabled=yes
then start talking to it with
serial-terminal serial0
Cheers,
JC
Users browsing this forum: No registered users and 13 guests
