ilius168
RB 1000 Upgrade RAM to 1GB?
Wed May 21, 2008 6:11 pm
HI
Can the SODIMM RAM on RB 1000 be upgraded to 1GB?
I'd appreciate any comments thx!
Gerard
Trainer
Trainer
Re: RB 1000 Upgrade RAM to 1GB?
Thu May 22, 2008 6:25 am
Yes,
I'm using the 2 gig version on a couple RB1000's on my network. The 1 gig version should work fine though.
Any DDR2 667 or faster SODIMM should work..
1 gig - http://www.newegg.com/Product/Product.a ... 6820134546
2 gigs - http://www.newegg.com/Product/Product.a ... 6820134549
-Gerard
Certified Mikrotik Trainer
MichelePietravalle
Trainer
Trainer
Wed Apr 22, 2009 11:46 am
Gerard, your routerboard see whole 2 gb?
i have just installed 2 gb and i see only 1,5
[admin@MikroTik] /system resource> pr
        uptime: 1m10s
        version: "3.23"
        free-memory: 1539956kB
        total-memory: 1556168kB
        cpu: "e500v2"
        cpu-count: 1
        cpu-frequency: 1333MHz
        cpu-load: 0
        free-hdd-space: 39268kB
        total-hdd-space: 61440kB
        write-sect-since-reboot: 143
        write-sect-total: 155774
        bad-blocks: 0
        architecture-name: "powerpc"
        board-name: "RB1000
i'm using kingston 2gb PC2-5300 SODIMM memory.
With 1 gb i don't see any problem.
kirshteins
Wed Apr 22, 2009 12:30 pm
Apparently
What's new in 3.19:
*) reduced maximum supported memory for RB1000 to 1.5Gb (was 1.75Gb);
MichelePietravalle
Trainer
Trainer
Wed Apr 22, 2009 1:01 pm
wow! ok, fine thanks!
normis
Wed Apr 22, 2009 1:02 pm
this is due to the hardware design, nothing we can do about it now
BigTrumpet
Thu Jul 16, 2009 12:17 am
which can be the reason to add more RAM on RB1000?
more PPPOE sessions to manage?
omega-00
Mon Jul 20, 2009 10:12 am
If you need something beyond what the RB1000 can handle, v3.27 is stable and has fully working multi-cpu support now.
Basically pick any standard dell or IBM server that has some decent processing power and a hardware warrenty and you're set :-)
janisk
Mon Jul 20, 2009 12:35 pm
more ram can be used for larger queue buffers, for proxying in RAM etc.
Users browsing this forum: No registered users and 24 guests
