MUM Europe 2020
jman12
RB433AH
Sun Jun 29, 2008 1:34 pm
Hi
Is the any chance the RB433AH will support SDHC cards
as the larger cards are all SDHC .
Jman
normis
Re: RB433AH
Mon Jun 30, 2008 9:02 am
The software should support SDHC, but we haven't tested any of the big ones. We tested 512, 1G and 2G only.
jman12
Re: RB433AH
Mon Jun 30, 2008 5:53 pm
Hi
Thanks for the reply Normis
I testesd with a 8Gig card and no luck
To read the 8Gig card in a PC i had replace my card reader with 1 that can do SDHC
2Gig aand under seem to work fine.
Regards
Jman
normis
Re: RB433AH
Tue Jul 01, 2008 9:48 am
it could also be related to the fact that the slot doesn't support some SD cards (not related to SDHC but some controller type). Maybe you could borrow another kind of 8Gb card and try that one.
jman12
Re: RB433AH
Fri Jul 04, 2008 6:09 pm
Hi
Ok i tried a Sandisk 8gig SDHC and no go i have also tried a Transcend 8gig SDHC and no go
I tried many brands of smaller SD cards and they all work even the no name one's
But none of the SDHC cards work.
Regards
Jman
cigamit
Re: RB433AH
Thu Jul 17, 2008 12:30 am
I've tried 2 different AData 2GB MicroSD cards, and can not get it to recognize them. Anything special I have to do?
normis
Re: RB433AH
Thu Jul 17, 2008 8:37 am
make sure you are using latest RouterBOOT and RouterOS v3.11
wwalcher
Re: RB433AH
Thu Jul 17, 2008 4:12 pm
Does the Web Cache work on the 433AH, or is it supported in an upcoming release?
jman12
Re: RB433AH
Thu Jul 17, 2008 9:32 pm
Great it now works with ROS 3.11
Thanks guys
Cool i got a 8 Gig proxy now
Jman
ihernandez
Re: RB433AH
Tue Jul 22, 2008 3:14 pm
"make sure you are using latest RouterBOOT and RouterOS v3.11"
Hello, I would like to know how do I upgrade to the latest RouterBOOT
Regards,
Ignacio
normis
Re: RB433AH
Tue Jul 22, 2008 3:28 pm
once you have upgraded to RouterOS v3.11, just type command:
/system routerboard upgrade
you will need to reboot. then type
/system routerboard print
to see if upgrade is successful
ihernandez
Re: RB433AH
Tue Jul 22, 2008 3:58 pm
Thank you, will do this and let you know how it went
Regards,
Ignacio
smacebr
Re: RB433AH - Voltage Monitor
Sat Jul 26, 2008 3:19 pm
Does RB433AH has VOLTAGE MONITOR ??? If not, I would like to know HOW EXPENSIVE is to have VOLTAGE MONITOR in Routerboards.
roc-noc.com
Forum Veteran
Forum Veteran
Sun Jul 27, 2008 2:37 am
Yes the RB433AH has the voltage monitor like the RB333. The present RB433 without AH do not. But future production RB433 are supposed to have this feature added.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
sistelec
RB433AH
Fri Aug 01, 2008 1:15 am
Hello Normis
My RB/433AH fail netinstall 3.8, 3.9 , 310, 3.11
FATAL ERROR: bad network connection
Press ENTER to reboot
Bios 2.16
normis
Re: RB433AH
Fri Aug 01, 2008 9:19 am
try another PC and cable
Tanker
Re: RB433AH
Fri Aug 08, 2008 2:24 pm
Good day to all
It would be REALLY cool to have the voltage monitor on these (NO!!! - ALL..!!!) RB's....
As kijomabb said... it would be FANTASTIC..!!!!
We have most of our BSS's lots of km away from us - and it makes the weekly "check" so much easier with Winbox if you could look at the voltages. I REALLY like these RB4AH's - but on some of our pivotal BSS we stick to the RB333's just so we can check on the voltages...
I can send Chocolates and Cigars - if it would help????? :lol:
Tanker
flik
Re: RB433AH
Fri Aug 08, 2008 8:08 pm
Does anyone know if the 1Gb Kingston microsd card works on a rb433ah? I inserted the card in the slot but it doesn't show up anywhere. I have a rb433ah with ros 3.11 and routerboot 2.16 .
Some cards need to be formated, how do I do it? Thanks
Flik
SurferTim
Re: RB433AH
Sat Aug 09, 2008 9:18 am
Hey Tanker! The RB433AH has a voltage monitor. Only with V3.11 tho. But read the posts about the hotspot challenges with V3.11 first before upgrading!
Tanker
Re: RB433AH
Sat Aug 09, 2008 1:03 pm
Hey Tim by the Beach
We have lots of RBAH's running on 3.11 ... unless I have missed something it still shows a nil voltage in /system health...
Also - we're not operating a lot of Hot spots at the moment... but watch this space..!! I'd just like to clear up all the planning before we roll-out the Hot Spot option when it is required. Our business model leans more towards FAC (far-away-clients) ~ 40 km+ in PtMP environments. Because of this we have lots of BSS situated a long way from us (SALWFU) -- can you tell I'm in "New Acronym Development Mode (NADM) today????
When the 333's came out and we could easily monitor input voltage - it was heaven sent..!!!! we like to stay on the "cutting edge" so when the AH's arrived and our BSS packet handling efficiencies rocketed - all looked so peachy - but - no voltage monitor. it's a "nice to have" feature. Not the end of the world - just NICE to have..!!!
But - I'm known for getting up in the morning and grabbing "Stuid Pills" - so i might have missed it..???
regards
Tanker
SurferTim
Re: RB433AH
Sat Aug 09, 2008 2:13 pm
Here is my RB433AH system health. I purchased it when they first came out, so it is an early version, if there is such a thing.
[admin@MikroTik] /system health> print
fan-mode: auto
use-fan: main
active-fan: main
voltage: 14
The voltage follows the battery charger voltage display.
Are you using the power input or PoE? Mine is on the power input.
On ROS V3.10 and below, it had no voltage monitor.
normis
Re: RB433AH
Mon Aug 11, 2008 9:14 am
also make sure you are running latest bootloader (2.16)
Users browsing this forum: techlord and 29 guests
