MUM Europe 2020
lormar
Help! 433 I did something really stupid!
Fri Aug 08, 2008 3:22 pm
I have a 433 and one r52 and one xr2. I was trying to get eoip to work with an original hotspot/AP running and using the r52 to connect/eoip and the xr2 as an AP. Well I put in an Ip address it didn't like and I see the wireless side for the XR2 10.10.10.1 but cannot connect to the rb with winbox. I tried going through the lan but same story. I am on an island and cannot find a null modem serial cable (who has these anymore anyway?) and tried to reset the RB using the switch but it doesnt work at all. Anyone have any ideas that I can try to get into the rb433 to fix my stupid?
Mark
normis
Re: Help! 433 I did something really stupid!
Fri Aug 08, 2008 3:25 pm
try using the MAC address in the winbox connection window. clicking on the [...] button will scan for the mac if you don't know it.
also try to hold down a metal object inside the metallic reset hole on the board, while booing. this will reset all config. it's not the button, but a small hole! check manual
lormar
Fri Aug 08, 2008 3:35 pm
I did try discovery and the MAC addy but to no avail. I did not realize that the links were seperate for the manual and specs on Routerboard.com. Looking now and thanks for the fast reply!
normis
Fri Aug 08, 2008 3:48 pm
try another ethernet port if the MAC is not found. you need to be directly connected to it via ethernet
lormar
Fri Aug 08, 2008 3:51 pm
Got It! Thanks for your help and also for a very reliable and full featured product. Have a few spots running and they have been 100% so far. Now to see if I can configure this without messing it up again.
Mark
normis
Fri Aug 08, 2008 3:52 pm
do it step by step, you can make export files ("/export file=conf") to save configuration at each step. try to utilize the Safe Mode (ctrl+x) which will undo the last step in case a config change disconnects you (as it happened for you now)
lormar
Fri Aug 08, 2008 3:56 pm
I will be cautious this time. Thanks again.
Hellbound
Long time Member
Long time Member
Thu Aug 21, 2008 8:22 pm
1. START + R
2. cmd > click ok
3. ping 10.10.10.1
4. arp -a
5. get mac address
6. paste in winbox
7. click connect
boardman
Mon Aug 25, 2008 3:44 am
Don't forget about CTRL-X (Safe Mode feature) for next time, if you screw things up, just power-cycle your Mikrotik and it will be just as it was before you started to mess with it. =)
Best Regards
Jorge Boardman
Users browsing this forum: BartoszP, dylan2228 and 18 guests
