MUM Europe 2020
HellMind
Rb 112 ROS 3.11, Lan port dies
Wed Aug 20, 2008 6:06 am
current-firmware: "2.16"
It cant work at 100 mbps
I see how the iface ether1 stop and start again
No error in logs
It just dies and then it's re link, several times every minute.
Now I've it configured to use only 10 Mbps, it works, but that's a shame
I changed everything but the rb112 itsefl, can be in the routerboard the problem?
Is there any report of this "bug"?
aaa
Re: Rb 112 ROS 3.11, Lan port dies
Wed Aug 20, 2008 5:10 pm
I know this "bug". That's lightening! You can use with 10mbit link but I am shure there is some packet lost.Or you can throw away.
HellMind
Mon Aug 25, 2008 8:56 am
Rb 112 bug :(
I spent in 50m FTP cable, and hand work to change the damn cable :(
Mikrotik can at least give me a replacement, or I'm asking too much ?
using the wifi link at 10mb, isn't an option.
Thanks for the reply
normis
Mon Aug 25, 2008 1:22 pm
did you read the previous post Hellmind? If that's a lightning strike, how is mikrotik responsible ? I'm not saying it is, I just think you should check that.
HellMind
Tue Aug 26, 2008 3:17 am
Ah sorry I didn't understood.
But a lightning strike will burn everything
how can it just make the eth0 work in low speed only?
How do I know if that was truly a lightning, I'm afraid of replacing it with another new, because there is nothing to stop it happen again.
jwcn
Tue Aug 26, 2008 4:43 am
Your right, lightening just like shit, happens. :-p
Users browsing this forum: No registered users and 18 guests
