mietus
ros 3.14 torrent is out but no seed since friday :P
Mon Sep 22, 2008 11:24 am
sorry for that kind of topic ;> but i cant download whole package and not only me 430 leech 0 seeds
normis
Re: ros 3.14 torrent is out but no seed since friday :P
Mon Sep 22, 2008 11:40 am
you sure? try again maybe, cause I can download fine
everyone else - please seed
che
Mon Sep 22, 2008 12:08 pm
Same here, I see bunch of 99,8% peers, and 0 seeders. I used HTTP links for specific architectures to get v3.14.
mietus
Mon Sep 22, 2008 12:11 pm
normis: :> sure im sure
0 seeds, 99.8 percent complete
regards
odie
Mon Sep 22, 2008 12:49 pm
99,8% here and no seeds also ;-(
tomekmak
Mon Sep 22, 2008 4:06 pm
same here :< 99,8% and 0 seeds....
tomekmak
Tue Sep 23, 2008 3:41 am
still cannot finish downloading... MT please do something...
normis
Tue Sep 23, 2008 9:51 am
working on it, should work in 30-60 minutes ;)
tomekmak
Tue Sep 23, 2008 11:14 am
still 0 seeds...
mietus
Tue Sep 23, 2008 11:58 am
don't push it ;P
normis
Tue Sep 23, 2008 2:23 pm
We made a new torrent, please re-download the ALL file
mietus
Tue Sep 23, 2008 2:27 pm
utorrent says that torrent not registered with this tracker :( still no seeds
after deleting old one and download a new one torrent file from mikrotik.com
*UPDATE
new torrent is downloading to a routeros-ALL-3.14_
folder
but 0 seeds 3 leechs
Letni
Tue Sep 23, 2008 2:48 pm
After re-downloading ALL file my torrent client is giving me this.
rejected by tracker - Torrent not registered with this tracker.
-Louis
tomekmak
Tue Sep 23, 2008 2:50 pm
same here...
mietus
Tue Sep 23, 2008 2:51 pm
do a save as a torrent file and save it to another location on your disk, delete old torrent in your software (i.e. utorrent) and load new one from disk
still 0 seeds
tomekmak
Tue Sep 23, 2008 2:56 pm
still the same error :(
normis
Tue Sep 23, 2008 2:58 pm
make sure you don't get the same torrent file, we noticed that it likes to be stuck in some proxy caches
mietus
Tue Sep 23, 2008 3:00 pm
normis: i think the best way to avoid this problem is changing the name of the file (i.e adding the _ to the torrent file name)
still no seeds :P
tomekmak
Tue Sep 23, 2008 3:09 pm
Im not using any proxy. I downloaded "new" torrent, changed name of this torrent, tried to download from different network, and problem is still the same...
mietus
Tue Sep 23, 2008 3:14 pm
try to ctrl + f5 on download page.
check if your torrent label in utorrent have a _ on the end
ze tak powiem po polskiemu
ma dzialac tylko ze nie ma seeda ;P
normis
mietus
Tue Sep 23, 2008 3:17 pm
mine md5 is
8355228f9c4f5f580518326b4ebd7e81 *routeros-ALL-3.14.torrent
03a1a6935ecd9ffde6dadc8188a09ca9 *routeros-ALL-3.14-FIXED.torrent
mietus
Tue Sep 23, 2008 3:18 pm
looks good but still the same :p no seed
mietus
Tue Sep 23, 2008 3:33 pm
ok i help with it, manually download this files put into download folder and reseed
:P
maybe normis wouldn't have to kill me :P
normis
Tue Sep 23, 2008 3:37 pm
some download started going :)
mietus
Tue Sep 23, 2008 3:38 pm
yep im seeding! ;P almost 1MB/s :p
mietus
Tue Sep 23, 2008 4:11 pm
ok, i ve done almost everything
but normis: you have to add only 3 files and seed
CHANGELOG_rc
routeros-mipsbe-3.14.npk
all_packages_mipsle\ppp-3.14-mipsle.npk
this files seems to be corrupted or smth
we still have 99.8% like before, maybe .torrent file is meesed up
mietus
Tue Sep 23, 2008 5:04 pm
ok. get new torent file from download page, it's working now
Users browsing this forum: No registered users and 17 guests
