manny
rb 433ah only shows running at 100MHZ
Sat Oct 18, 2008 5:33 am
rb 433ah only shows running at 100MHZ . I don,t know how it happened and can I set it back to the correct setting.
Great Man
Re: rb 433ah only shows running at 100MHZ
Sat Oct 18, 2008 10:03 am
It happened me too when i upgraded the BIOS. Just set the cpu-frequency (run telnet or terminal) and it will work correctly again.
system routerboard settings set cpu-frequency=680MHz
NetworkPro
Fri Jan 16, 2009 8:07 pm
What is this setting about: /system routerboard settings set cpu-mode=power-save|regular ?
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
roadrunner
Mon Jan 19, 2009 11:11 pm
http://www.mikrotik.com/testdocs/ros/2. ... rboard.php
cpu-mode (power-save | regular; default: power-save) - whether to enter CPU suspend mode in HTL instruction. Most OSs use HLT instruction during CPU idle cycle. When CPU is in suspend mode, it consumes less power, but in low-temperatire conditions it is recommended to choose regular mode, so that overall system temperature would be greater
Leave it on the default of power-save unless you will be experiencing temperatures below -15 Celcius (1 F), setting it to regular will help the CPU keep itself warm enough.
This setting should only be available on rb100 & rb500 series routers. Atleast I don't see it on my rb600 nor any rb4xx boards.
Vitis
Tue Jan 20, 2009 12:55 am
I have it on RB4xx series (I can´t check just on RB493, but on RB493AH I found it).
Users browsing this forum: psannz and 26 guests
