MUM Europe 2020
triac
RB450 with routerOS 3.22 say "system rebooted..."
Tue Apr 21, 2009 6:49 pm
Hi, I have some RB450 with a problem... the routers reboot itself often and I have this message in log list: "System rebooted because of kernel failure".
What's happen?
UPDATE!!!! Same problem with RB493!!!! It's a RB4XX bug?
Paolo Torri
Flavioweb
Re: RB450 with routerOS 3.22 say "system rebooted..."
Fri Apr 24, 2009 2:54 pm
Also i have this problem with an rb133c, since ROS 3.1X (actually 3.22 installed).
Many users have this "feature" enabled ( :D try to search "kernel failure" in this forum), but, at this point, i think there are no other side-effect than the initial message in log.
All my hardware works fine, but the message still here... after every reboot.
Same packages, used to upgrade a rb100, works fine.
All bioses and ros are always upgraded to latest versions.
normis
Fri Apr 24, 2009 3:01 pm
you have to make a supout.rif file after the reboot, and send it to mikrotik support. we will look and fix whatever problem caused this. it's most likely related to some specific configuration
Users browsing this forum: No registered users and 38 guests
