nomade
RB493 & Netinstall
Thu May 07, 2009 1:53 pm
People, my router has been having problems.
RouterBOOT booter 2.18
RouterBoard 493
CPU frequency: 300 MHz
  Memory size:  64 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Wen try to NetInstall
RouterBoard 493
  Memory size:  64 MB
trying bootp protocol... OK
Got IP address: 10.1.1.10
resolved mac address 00:0F:B0:F8:05:D7
transfer started ........................ transfer ok, time=1.85s
Does anybody have any ideas?
Tranks
Letni
Re: RB493 & Netinstall
Thu May 07, 2009 2:44 pm
I recall seeing this issue once when the desktop I was using to netinstall from had 2 NICS. I believe disabling all other NIC's than the one that was connected to RB fixed the issue.
If that does not take care of it, you could try upgrading the firmware first. MT has available 2.19 on the routerboard.com website. I am running 2.20 on mine and is included with 3.23, you may need to e-mail support for a copy of it though.
-Louis
Users browsing this forum: No registered users and 88 guests
