dormador
if you want to see my test .... rb433a + rb411a
Sat May 16, 2009 10:30 pm
Hi all
gentleman
with my own test for two board from mikrotik i see these result ...my card is xr5 with 30dbi antenna for all
the big rate that can 411a transfer is 28mbps the regular rate is 23mbps the minimum rate is 20mbps
the big rate that can 433a transfer is 58mbps the regular rate is 52mbps the minimum rate is 48mbps
with extream and turbo mod......
am doing the best i can.......
is that good result ! ! i dont know
regards
InoX
Re: if you want to see my test .... rb433a + rb411a
Sun May 17, 2009 7:36 pm
:lol:
dormador
Mon May 18, 2009 8:55 am
inox
it is 433ah isn't it?
or 433a ?
am waiting
regards
InoX
Mon May 18, 2009 6:17 pm
433...411 and 433AH will have the same results because that is the max. speed of a radio modem.
dormador
Tue May 19, 2009 2:15 pm
Mr InoX
are you sure about this reference ? !
because i have many point the same card the same antenna but it gives me different rate !
e.g the 133 router board the maximum rate is 20Mbps ... put any card .... never take up 20Mbps ....
my information are the cpu and ram have impress for the rate !
i don't know until now if this write or wrong ....
can you tell me more about this part ?
regards
InoX
Tue May 19, 2009 2:36 pm
I wasn't talking about RB133
ilius168
Sun May 24, 2009 4:22 pm
HI Inox,
Is that real traffic or bandwidth test?
What is your cpu usage at that speed?
Regards
Users browsing this forum: No registered users and 85 guests
