bulentkusva
How do load balancing 8 adsl modem?
Thu May 28, 2009 10:03 pm
I can do with routerboard 433ah routeros version 3.24 ?
adsl1 lan ip :192.168.2.1
adsl2 lan ip :192.168.2.2
adsl3 lan ip :192.168.2.3
adsl8 lan ip:192.168.2.8
gtrappmann
Re: How do load balancing 8 adsl modem?
Sat May 30, 2009 11:29 am
thats an interesting question ... maybe it runs if you find a solution to put 8 ethernet cables in 3 ethernet ports...
itsh.net
Sat May 30, 2009 1:40 pm
entirely my opinion, to find a solution to 2/4/8ADSL (PPPOE) access to the pool, I would be interested also burning ..
A Routerboard RB493 one would think that I need to be perfect.
bulentkusva
Sat May 30, 2009 6:44 pm
/ip firewall address-list
add address=10.0.0.2-10.0.0.35 comment="" disabled=no list="gr 1"
add address=10.0.0.36-10.0.0.99 comment="" disabled=no list="gr 2"
add address=10.0.0.100-10.0.0.132 comment="" disabled=no list="gr 3"
add address=10.0.0.133-10.0.0.155 comment="" disabled=no list="gr 4"
add address=10.0.0.156-10.0.0.185 comment="" disabled=no list="gr 5"
add address=10.0.0.186-10.0.0.220 comment="" disabled=no list="gr 5"
add address=10.0.0.221-10.0.0.254 comment="" disabled=no list="gr 6"
add address=10.0.1.1-10.0.1.89 comment="" disabled=no list="gr 7"
add address=10.0.1.90-10.0.1.170 comment="" disabled=no list="gr 8"
/ip firewall mangle
add action=mark-routing chain=prerouting comment="" disabled=no new-routing-mark=grup1 passthrough=yes \
src-address-list="gr 1"
add action=mark-routing chain=prerouting comment="" disabled=no new-routing-mark=grup2 passthrough=yes \
src-address-list="gr 2"
add action=mark-routing chain=prerouting comment="" disabled=no new-routing-mark=grup3 passthrough=yes \
src-address-list="gr 3"
add action=mark-routing chain=prerouting comment="" disabled=no new-routing-mark=grup4 passthrough=yes \
src-address-list="gr 4"
add action=mark-routing chain=prerouting comment="" disabled=no new-routing-mark=grup5 passthrough=yes \
src-address-list="gr 5"
add action=mark-routing chain=prerouting comment="" disabled=no new-routing-mark=grup6 passthrough=yes \
src-address-list="gr 6"
add action=mark-routing chain=prerouting comment="" disabled=no new-routing-mark=grup7 passthrough=yes \
src-address-list="gr 7"
add action=mark-routing chain=prerouting comment="" disabled=no new-routing-mark=grup8 passthrough=yes \
src-address-list="gr 8"
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.2 routing-mark=grup2 scope=30 \
target-scope=10
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.3 routing-mark=grup3 scope=30 \
target-scope=10
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=grup1 scope=30 \
target-scope=10
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.4 routing-mark=grup4 scope=30 \
target-scope=10
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.6 routing-mark=grup6 scope=30 \
target-scope=10
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.5 routing-mark=grup5 scope=30 \
target-scope=10
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.7 routing-mark=grup7 scope=30 \
target-scope=10
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.8 routing-mark=grup8 scope=30 \
target-scope=10
in this way was
but it must be different
http://wiki.mikrotik.com/wiki/PCC
PCC according to how do we do?
JorgeAmaral
Trainer
Trainer
Tue Jun 02, 2009 2:50 am
In my opinion, you should use the adsl modems has modems, not has routers.
Buy a 16port managed switch, create 8 vlans on the switch. Like (vlan100 "port 1 untagged and port 9 tagged"), (vlan101 "port 2 untagged and port 9 tagged"), etc... until you have all the 8 vlans.
Then go to mikrotik, add the 8 vlans on the port that connects to the switch tagged port, create 8 pppoe-client interfaces, and select the vlans as "master interface" for each pppoe-client . When you add the pppoe-client interface, do not select "add default route". Instead add a default route manualy, like dst-address="0.0.0.0/0" interface="pppoe-client" check-gateway=ping
Then make the balance of all your 8 lines with PCC based on src-address/dst-address.
Jorge Amaral
NetworkPro
Fri Aug 14, 2009 5:49 pm
Jorge Amaral
I confirm this to be a good way to do it, arguably the best way to do it. Thank you JorgeAmaral for being helpful.
jasejames
Fri Aug 14, 2009 10:12 pm
I'd also add that if you are in Europe (or any other area that uses PPPoA rather than PPPoE), the Draytek 100/110/120 bridges are an excellent way of doing this.
Zero config on the Drayteks, they simply convert PPPoA to PPPoE. Plug these in and go.
Users browsing this forum: No registered users and 10 guests
