MUM Europe 2020
kassemkhaled
lost key rb133
Thu Jun 04, 2009 9:47 pm
yesterday rb 133 stopped fuctioning even its disappeard from winbox i connect by cable console and found demo expaired ,howcome! after many searching saying that LICENSE key expaired. reinstall os allpackage 2.9.51 by netinstall as said in mikrotik. now i can see and inter the rb by win box but its 24 hours LICENSE why how can get my LICENSE key back
normis
Re: lost key rb133
Fri Jun 05, 2009 9:14 am
just apply the old key, it's in your mikrotik.com account probably
to avoid this in the future, upgrade the bootloader of Rb133
kassemkhaled
Re: lost key rb133
Fri Jun 05, 2009 10:14 am
sorry iam new on this where to apply for my key
normis
Re: lost key rb133
Fri Jun 05, 2009 10:21 am
log into www.mikrotik.com where all your keys are
copy the key that has the same SoftID as you see in your router
paste this key into your router
kassemkhaled
Re: lost key rb133
Fri Jun 05, 2009 10:35 am
before i reinstall os i copy this from netinstall "K9MF-3TT key:
u6u/+7+3TOZ+bvd2hL69/DYt/7v807//v6f+rPdv9+1/nfp1wjb//v0/////ETs/17v/C5s//n///27r
fW/93A==" is this the key
normis
Re: lost key rb133
Fri Jun 05, 2009 10:39 am
this one should be correct:
-----BEGIN MIKROTIK SOFTWARE KEY------------
u6Ok+7ckSMYWLidwgKYd7DYt+LN4Ur3juidqDHZvE815
FaBwwgaduvU/H/HxESsvU7vQA4sv5h/vdi6jVGvJ1A==
-----END MIKROTIK SOFTWARE KEY--------------
copy it, and paste it into any level of menu when connected with Telnet. Or connect with winbox and use Paste Key button in License menu.
kassemkhaled
Re: lost key rb133
i try copy past but its says cannt change key invalid key
kassemkhaled
Re: lost key rb133
Fri Jun 05, 2009 10:44 am
thank u very mush really u r a life server and made by mt :D
mobilexpert
Re: lost key rb133
Sun Nov 10, 2013 11:54 pm
I have some old RB133c,
I wanted to update to higher version (was 2.9.51),
and after putting 3.30 (for key change),
now it says DEMO ... 24h key ....
can you help please, I want it working again ...
KEY: 6VBD-AAKY ; RB-133c (3x mini-pci)
thanx in advance.
b.r.
Alex
Users browsing this forum: No registered users and 20 guests
