jkohan
Need to install OpenWRT on a 433AH, can later restore ROS ?
Fri Jul 03, 2009 8:37 pm
Hi.
For a particular project, We need to run OpenWRT on a 433AH, AND access the SD card from it.
But I don´t want to lose the possibility of later restoring RoS.
(We use OpenWRT because need to run some housemade programs on the board, mktk scripting isn`t enough for those)
1- The ideal thing would be beeing able to boot OpenWRT from the SD, but the person doing it says RB can´t boot from SD.
2- The second thing we tried was to use Ros 4 virtualization and boot OpenWRT. The problem is that apparently the guest can´t see the SD as storage.
3- So, we are evaluating to flash OpenWRT on the Nand storage. The questions are:
a) Would we be able to use the SD from OpenWRT ?
b) If we determine RB433AH isn´t suitable for this project, can we restore RoS to use it as a "normal" RB ?
Thanks in advance
Javier
normis
Re: Need to install OpenWRT on a 433AH, can later restore ROS ?
Mon Jul 06, 2009 11:26 am
yes, you should be able to restore RouterOS just fine. We will check why SD card didn't work.
jkohan
Mon Jul 06, 2009 7:35 pm
How do I restore ROS ? From the BIOS prompt, via serial ?
normis
Tue Jul 07, 2009 9:20 am
oreggin
Fri Oct 16, 2009 9:31 pm
I was format the NAND flash and I can't restore the RouterOS on my RB450G with Netinstall.
When I start the Netinstall, it can boot the router, and the router is wait for the installation server, but nothing else.
I select the proper package and sometimes I select the previously saved license file but nothing.
Netinstall4.1 indicate "Sending offer..." for 5-10 second but the router don't see the installation server.
I was try on all port with 3 UTP cable, 2 PC, 3 versions of Windows but nothing happens after the router booted up the kernel provided by netinstall.
I was try some of the Netinstall versions from 3.26 to 3.30 and from 4.00 to 4.01 too.
Any idea?
oreggin
m4rk0
Fri Oct 16, 2009 9:51 pm
http://www.mreza-wisp.ba/
Please, give Karma if I fix your problem
Certified MTCNA
oreggin
Fri Oct 16, 2009 9:59 pm
Me?
m4rk0
Sat Oct 17, 2009 12:11 pm
Me?
No, jkohan ;)
Certified MTCNA
oreggin
Sat Oct 17, 2009 12:45 pm
He sed:
"2- The second thing we tried was to use Ros 4 virtualization and boot OpenWRT. The problem is that apparently the guest can´t see the SD as storage."
Users browsing this forum: No registered users and 14 guests
