MUM Europe 2020
smurphy
No reboot on RB493AH with RouterOS 3.2x
Mon Sep 07, 2009 12:40 pm
Hi there folks,
anyone experiencing reboot issues with RB493AH with RouterOS 3.2x ?
Actually - I only noticed it when the watchdog was rebooting the box due to non availability of a remote system.
It just reboots - then is stuck on the boot-menu.
Even if I tell it to reboot manually - connected through Serial Console to a linux box - however nothing is running on the serial terminal except when I connect to it using minicom - I see the messag where I have 2 Seconds to go to the boot menu - and then it jumpts into the boot menu anyway and waits.
Anyone has a hint on what to do ? It's kind of stupid if I'm away and have to ask "non-admin" people to go through the process to connect with minicom etc. and that box over the phone).
Booting is configured to go from NAND then from Ethernet. However - nothing to do.
smurphy@gw-sollan-RB493AH] /system routerboard> print
       routerboard: yes
             model: "493AH"
     serial-number: "XXXXXXXXXXXXXXX"
  current-firmware: "2.20"
  upgrade-firmware: "2.20"
[smurphy@gw-sollan-RB493AH] /system> watchdog print
     watch-address: XXX.XXX.XXX.XXX
    watchdog-timer: yes
     no-ping-delay: 5m
  automatic-supout: yes
  auto-send-supout: no
and
[smurphy@gw-sollan-RB493AH] /system routerboard settings> print
            baud-rate: 115200
           boot-delay: 2s
          boot-device: nand-if-fail-then-ethernet
       enter-setup-on: any-key
        cpu-frequency: 680MHz
        boot-protocol: bootp
  enable-jumper-reset: yes
  force-backup-booter: no
mrz
Re: No reboot on RB493AH with RouterOS 3.2x
Mon Sep 07, 2009 12:59 pm
Try to set in bios boot key <Delete> instead of any key.
smurphy
Tue Sep 08, 2009 11:45 am
Looks like that helped. However I still wonder why the any-key option prevents it from booting.
I'll monitor it for a while. Thx for the hint.
mrz
Tue Sep 08, 2009 11:47 am
If something is connected to serial port it may send some symbols which triggers bios menu.
Users browsing this forum: No registered users and 20 guests
