MUM Europe 2020
triac
Failover with UMTS backup
Sat Oct 31, 2009 10:24 am
Hi folks,
I need help about failover configuration using ADSL as primary link and UMTS router as backup link...
I have ADSL router connected to eth1 of my RB450 router and UMTS router connected to eth2... I've tried to make it following this example found in wiki:
"/ip route add gateway=192.168.1.1 check-gateway=ping
/ip route add gateway=192.168.2.1 distance=2"
... don't work... if DSL carrier goes down MT router can ping ADSL router because it's alive, and MT don't switch gateway...
If I try to switch off the ADSL router manually the MT switch to second gateway...
can anyone help me?
Tnx
Paolo
Paolo Torri
Demeo
Re: Failover with UMTS backup
Sat Oct 31, 2009 12:52 pm
You need to configure your DSL as bridge, and set static route to gateway for the bridge...
triac
Sat Oct 31, 2009 2:01 pm
Hi Demeo, tnx for reply,
I cannot use bridge mode because my ADSL provider ask me PPPoA auth and MT router cannot make this... or I can't know how to made it... :(
Paolo Torri
Demeo
Sat Oct 31, 2009 2:11 pm
So use script, wich will ping some host in Inet and switch your routes. Or just use netwach tool in ROS
Users browsing this forum: No registered users and 18 guests
