dingsingo
New Routerboard RB/800 is coming
Tue Nov 17, 2009 6:19 pm
very fine...
MPC8544 800MHz
Memory 256MB DDR SDRAM onboard memory
Boot loader RouterBOOT
Data storage NAND memory chip, CF slot on back
Ethernet Three 10/100/1000 Mbit/s Ethernet ports with Auto-MDI/X
miniPCI 4 x miniPCI, 1 x miniPCI-e
Expansion regular PCI daughterboard port, PCI-e daughterboard port
Extras Reset switch, Beeper, 4x Fan headers (JP1,JP3 = 3.3V, JP2,JP4 = 5.5V)
Serial port One DB9 RS232C asynchronous serial port, One serial port header
LEDs Power, 1x User LED
Power options Power over Ethernet: 36-56V DC (including power over datalines)
Power jack: 10-56V DC
Dimensions 14 cm x 20 cm (5.51 in x 7.87 in), 285 g
Operating System MikroTik RouterOS v4, Level5 license
Two port throughput 276000pps with small packets, and wire speed throughput on big packets
rb800.pdf
dingsingo
Ibersystems
Re: New Routerboard RB/800 is coming
Tue Nov 17, 2009 8:21 pm
is coming since 2007... xD
Post subject: Re: RouterBOARD 333 AND RouterBOARD 1000 - a preview ?
PostPosted: Fri Jun 01, 2007 10:50 pm
Here's some more news from mum. These boards look awesome btw..
new router boards will only work with version 3 due to the new ppc architecture
RB333 has 64 megs of ram, 0-30volt input, 2-3x faster than RB532 at 400mhz
RB192 with 9 ethernet ports and 2 mini pci, rest is same as RB133
new daughter board for RB500/600 series has 16 ethernet ports, don't know if its just a switch or shown as 16 ethernet ports. someone asked the question and their response was "yes".. Will be interesting to see..
2 new in development products but "nothing is set in stone"
RB800 with mini pci express and mini pci slots.. "also will be very fast"
RB400 gigabit ap..
They also mentioned something about some of the new boards using a common screw layout to make things easier for us in the future..
I will try to post pictures of the slides soon as I get a chance.. (leaving for the airport in a few)
-Gerard
But is a great board to "change" the RB600s.
Thanks!
Martín Ruiz
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in:
MTCNA - MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE - MTCSE
honzam
Wed Nov 18, 2009 12:08 am
When to start selling?
LAN, FTTx, Wireless. ISP operator
nz_monkey
Wed Nov 18, 2009 1:00 am
WOO HOO, finally...
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
roc-noc.com
Forum Veteran
Forum Veteran
Wed Nov 18, 2009 6:12 am
Should begin shipping in December 2009.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
dolphinik1
Sat Nov 21, 2009 12:32 am
RB800 have unreal high price 440$(I see it on roc-noc.com) :(
miniITX motherboard with dual core CPU Intel Atom 1.6GHz + 512DDR2 = 100$
power suply+POE 70$
RB/14 = 30$
L5 license 95$
295$
roc-noc.com
Forum Veteran
Forum Veteran
Sat Nov 21, 2009 9:32 am
power suply+POE 70$
RB/14 = 30$
L5 license 95$
295$
I am not sure what you are looking at. It has never been $440 on our site.
http://www.roc-noc.com/product.php?prod ... t=5&page=2
Yes, the Atom is an amazingly inexpensive processor. There have always been cheap PC based alternatives for building Routers but then you are missing the point of a RouterBoard. It is a single board computer made by Mikrotik with RouterOS installed and supported by Mikrotik.
OTOH I would love to see an Atom based Mikrotik designed RouterBoard. :)
Tom
888-762-5662
thmumcglobal
Wed Dec 02, 2009 12:51 am
Does the RB/800 come with a SIM-CARD Slot to support 3G PCIe Radios?
normis
Wed Dec 02, 2009 8:47 am
no, that slot doesn't support 3G modems
w0lt
Thu Dec 03, 2009 9:09 pm
When in December, now that December is here :)
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
csallor
Fri Dec 04, 2009 12:02 am
-tp
2011 December :D
roc-noc.com
Forum Veteran
Forum Veteran
Fri Dec 04, 2009 1:43 am
Funny guy.... mid December 2009 unless they are delayed.
Tom
888-762-5662
roc-noc.com
Forum Veteran
Forum Veteran
Tue Dec 15, 2009 10:03 am
-tp
They have shipped from Mikrotik and we should have them in stock on either Friday the 18th or next Monday the 21st.
Tom
888-762-5662
ginovilla
Tue Dec 15, 2009 4:28 pm
How about some info on the daughter cards?
Would we see a PCI-e 6 GE port expansion card?
roc-noc.com
Forum Veteran
Forum Veteran
Mon Dec 21, 2009 3:09 am
It has arrived. I took a picture of one in a case today.
http://www.roc-noc.com/images/P/RB800-complete-logo.jpg
Tom
888-762-5662
w0lt
Mon Dec 21, 2009 2:46 pm
Is it possible to get this Mini-PCIe GPS card to work in the RB800 Mini-PCIe slot? That would be really great !!
http://www.azurewave.com/product_GPS-M01_1.asp
-tp
MTCNA - 2011
normis
Mon Dec 21, 2009 2:51 pm
you can buy it, plug it in, make supout.rif file, and we will see if it's possible :)
conjurer
Tue Jan 05, 2010 2:26 pm
Why not via nano? It has hardware encryption capabilities.
normis
Tue Jan 05, 2010 2:30 pm
mjj
Thu Jan 07, 2010 4:32 pm
First test of RB800 = replacing old RB600+RB604 (8 mPCI modules). Effect? Problems with signal quality, stability of links. Signal's strengh not changed. Any idea? Is RB800 making any RF problems?
uldis
Thu Jan 07, 2010 4:47 pm
What RouterOS you had on the RB600?
mjj
Thu Jan 07, 2010 8:12 pm
On RB600 I had 3.30, on RB800 4.3 is working now.
P.S. On RB800 i have fake voltage measurement: 30,1 V while real voltage on power supply is 27,5 V. This issue we have on RB411AH too. But only when using PoE.
uldis
Fri Jan 08, 2010 10:02 am
please contact support@mikrotik.com with the support output file from that board.
ne0031
Fri Jan 08, 2010 10:09 pm
It's a shame it uses a fan, thus we will never buy any.
Matt
ABC/WXYZ - you get the picture.....
150khz-110ghz
1/5sps to 100gbps
normis
Mon Jan 11, 2010 2:48 pm
Fan is optional. We have a RB800 here running bandwidth test for 4 hours, FAN is off. It works fine, although the temperature is a bit high. We changed the heatsink to a little bigger one, and it's now completely normal.
ne0031
Mon Jan 11, 2010 5:40 pm
Is that larger heatsink an option?
Matt
150khz-110ghz
1/5sps to 100gbps
normis
Tue Jan 12, 2010 9:26 am
Not currently, but maybe you can figure something out if you ask our sales dept.
ste
Wed Jan 13, 2010 9:15 am
You should make Fanless as standard. I never would buy a RB for an outdoor AP with Fan.
Fan's are dying after 2-6 years depending on quality, rotation speed and temperature conditions.
So we would have a sure repair outage for every board. Outages on towers are expensive.
normis
Wed Jan 13, 2010 9:20 am
this is why the RB800 has four fan connectors, and you can make two fans rotate at the same time, while two others wait to kick in after one of the first two dies :)
normis
Mon Jan 18, 2010 3:29 pm
we have updated our routerboard webpage to include performance tests of RB800 and also RB750
Trezona
Tue Feb 02, 2010 11:11 am
Hi Normis,
I have noticed in the bios there are options there to over clock the rb800 to 1333Mhz.
Is this truly possible on this board without damaging anything?
Trez.
normis
Tue Feb 02, 2010 11:13 am
Yes, you can, but watch for stability issues, it depends on your particular installation and configuration.
marlow
Sat Mar 06, 2010 12:37 am
I got a few in the door and very nice performance.
A few annoying things:
- The 16 x 10/100 lan daughterboard is available now, but no case for the RB600 and RB800 for that. What's the timeframe for the case ?
- Supporting a 3G mPCI-e modem with SIM-card slot would have been a very good thing. Maybe a daughterboard that takes the mPCI-e modem and has a SIM-card holder could be provided in time. It would really be nice to have.
/M
Communication is the beginning of understanding
-- AT&T
paams
Sat Sep 16, 2017 7:22 am
Hello Mikrotik Team! I want to link six PtP long distance links in different directions from one top hill remote base station site and looking to buy a Mikrotik RB800 router board for this purpose to link different sites at different locations. But when contact with some disturbers they said that this is an obsolete router board model from Mikrotik and now a days no longer in use in the field for wireless networking. Is it true that its useless after buying this routerboard? Please assist and guide me on this. Any valuable help from Mikrotik expert team will be greatly appreciated. Thanks.
BartoszP
Sat Sep 16, 2017 9:04 am
Oh, boy .... 7 years old thread ... do you really want to use such old device ... look for new equipment with guarantee
Real admins use real keyboards.
paams
Sat Sep 16, 2017 5:06 pm
Hello BartoszP! thank you very much for your prompt assistance to me. I really heartily appreciate. Actually, why i was looking for RB800 board because it was using four radio cards and extra radio cards on daughter board which seems good option to use single RB with many PtP/PtMP radio links to different site locations. As per my project requirement i need 6-8 PtP long range 15km plus links at differently located remote sites from one base station site. And there is no such RB in the market which can provide Maximum of 8 radio (wlan) links from a single RB such as was available with single RB800. I hope you understand my concern and assist me further if you know such newly launched single RB equipment from Mikrotik as per my intended wireless networking project. Thanks.
BartoszP
Sat Sep 16, 2017 7:07 pm
But why are waking up 7 yers old "zombie" :) instead of starting new thread?
EDIT:
Answer moved to: viewtopic.php?f=2&t=125686&p=618825#p618825
marlow
Sat Sep 16, 2017 8:25 pm
The more radio cards you use on one board, the less CPU power you have per card. That affects your radio time.
With 802.11n and ac speeds, you see the performance for each link drastically drop. So to get the maximum performance per link, it's best to use one board per radio card. Using 2 or 4 cards on a RB800 was valid, when 802.11a og 802.11g was the standard used.
By todays standard, I'd use max 1 card on the board to maximize my throughput, especially when using nv2 and other extra features.
I still have RB600 and RB800 boards in use ... they're a good board. But if you're about to buy new, they'd be a bit outdated.
/M
-- AT&T
Users browsing this forum: YaCy [Bot] and 23 guests
