MUM Europe 2020
pollo
rb1000u
Thu Dec 03, 2009 11:51 pm
Hi i have q 1000u with 4.3 all packages
i confgured ether1 as wan with public ip,
and dhcp and dns on ether4
im able to log in the 1000u from the internet using another connection and winbox, by public ip but i have a 206.XX.XXX.98/27
and the internet is not passing to lan interface, also i tried to do the firewall mapping1.1
ip firewall nat add chain=srcnat src-address=11.11.11.2-11.11.11.31 \
\... action=netmap to-addresses=206.xx.xxx.98-207.xx.xxx.126
invalid value for argument max
ip firewall nat add chain=dstnat dst-address=206.xx.xx.98-207.xx.xxx.126 \
\... action=netmap to-addresses=11.11.11.1-11.11.11.31
value of range must have ip address after '-'
thanks for the help in advance.
sergejs
Re: rb1000u
Mon Dec 07, 2009 8:29 am
Use the following syntax
dst-address=1.1.1.0/27
and the same for src-address.
pollo
Re: rb1000u
Mon Dec 07, 2009 8:41 am
Thanks i went on the web box and enabled the nat and that worked..
now i have problem with nat and firewall
sergejs
Re: rb1000u
Mon Dec 07, 2009 9:05 am
Webbox adds basic configuration, you have to apply rules manually if you want advanced firewall/nat configuration.
Users browsing this forum: No registered users and 12 guests
