medube
Time keeps resetting
Thu Jul 21, 2005 2:59 am
Hi all,
I have 2 routerboards in one pop which have their times reset to 00:00:00 Jan 01 1970 everytime they are rebooted. I have nearly 10 routerboards running MT for over 1 year, but haven't seen such problem before.
Does it have anything to do with CMOS battery? Anyone got suggestions pls?
Thanks.
normis
Thu Jul 21, 2005 9:15 am
use NTP and synchronise the time with a reliable time server
sten
Forum Veteran
Forum Veteran
Re: Time keeps resetting
Thu Jul 21, 2005 12:09 pm
That would be what the battery was there for. Try replacing them.
jonbrewer
Sun Oct 23, 2005 8:29 am
Clock doesn't work with any of our 12 RB532 units deployed - and NTP doesn't work either. This is a serious bug.
sergejs
Sun Oct 23, 2005 3:33 pm
if you have correct NTP client configuration, clock works fine in RB500.
jonbrewer
Tue Oct 25, 2005 11:04 am
Yes, the NTP server works. It is the national NTP server for New Zealand. All our Debian boxes use it. No, it doesn't respond to ping.
[admin@ara-imperial] > /system resource print
uptime: 1w7h32m33s
free-memory: 18936kB
total-memory: 30384kB
cpu: "MIPS 4Kc V0.10"
cpu-frequency: 266MHz
cpu-load: 7
free-hdd-space: 98976kB
total-hdd-space: 126976kB
write-sect-since-reboot: 0
write-sect-total: 0
[admin@ara-imperial] > /system ntp client print
enabled: yes
mode: unicast
primary-ntp: 131.203.16.6
secondary-ntp: 0.0.0.0
status: started
[admin@ara-imperial] > /system clock print
time: 07:32:03
date: jan/08/2000
time-zone: +12:00
kenk
Tue Oct 25, 2005 12:30 pm
Johnbrewer,
Are you in the Chathams or somewhere in Year 2000. Your NTP server has started, but time has not been set. It should be saying
status: synchronized and correct time and year.. Maybe it hadnt had time.
KenK
Ken Kirkby
jonbrewer
Tue Nov 01, 2005 11:02 am
Johnbrewer,
KenK
Nope, just in NZ. GMT +12.
Clocks on our 12 RB532 boxes still don't work. Can anyone help?
REDTDI
Tue Nov 01, 2005 8:52 pm
There are no batteries on RB500 series routers. You have to use NTP servers or else the clock is reset after every reboot.
Ken
astanley
Wed Jan 18, 2006 8:48 pm
Johnbrewer,
KenK
Maybe.
If you use Winbox, using "Tools" ping your NTP server.
If you get "no route to host" or "timeout", using "IP" "Routes" add a static route to 0.0.0.0 using your default gateway.
I just came across your post, hope this helps.
Users browsing this forum: Paternot and 44 guests
