MUM Europe 2020
lanscene
is there a windows driver for r52n
Tue Feb 09, 2010 3:59 pm
i have installed r52n with a minipci-pci adapter in my pc, the hardware is found , but the windows driver recommended by mikrotik can't recognize the card ,
after i manually install the driver , in device manager the card look well , but it can't find any ap whatever using microsoft's wifi configuration in windows or using
atheros's utility shipped with driver , can anyone help me , thank you in advance !
normis
Re: is there a windows driver for r52n
Wed Feb 10, 2010 8:42 am
did you look here? http://www.atheros.cz/
lanscene
Wed Feb 10, 2010 8:57 am
of course , i have mentioned in my message , i have test the driver download from the atheros.cz , the driver can only install by manully (by force) , maybe the VID/DID is not
include in INF file , the driver seemed install correctly , but can't work indeed.
lanscene
Fri Feb 12, 2010 7:15 am
does anyone else use r52n in a pc , why not do a test
syddavis
Wed Nov 10, 2010 2:53 am
Was anyone ever successful installing the R52Hn miniPCI network adapter in a Windows machine? :?
-Steve
0ldman
Tue Nov 30, 2010 10:42 pm
I'm running one in mine.
Better range than the R52 but I cannot get N speeds working.
klricks
Sun Jan 23, 2011 4:51 pm
Can you give details of how you got your card working?
I installed the drivers but XP says no driver installed when looking at the card via device manager.
pd
Thu Jun 14, 2012 1:16 pm
The ONLY way I found was to FORCE it to install as an Atheros 922x card...
enverrinke
Tue Nov 20, 2012 8:23 am
no way forcing r52hn in atheros.cz drivers.
searched in google a lot and no driver for windows.
anyone have this driver?
thx.
0ldman
Fri Jan 11, 2013 7:03 am
same driver for the r52n and r52hn.
I figured out my lack of N speed problem, enabled AES.
Users browsing this forum: vortex and 24 guests
