MUM Europe 2020
siscom
RB600 missing from Routerboard.com
Fri Mar 12, 2010 9:30 pm
Any idea why the RB600 is missing from routerboard.com website?
Got me a bit worried there .... :?
Rgds,
Mark.
nz_monkey
Re: RB600 missing from Routerboard.com
Sat Mar 13, 2010 12:26 am
It has been superseded by the RB800
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
kubby
Trainer
Trainer
Sat Mar 13, 2010 10:40 am
Rgds,
Mark.
RB600 EOL, production end, replace with RB800
我是商人-I am just a trader
siscom
Sun Mar 14, 2010 12:07 am
Thank you for the info.
Hope the RB800 proves as reliable as the RB600 was ...
Rgds,
Mark
roc-noc.com
Forum Veteran
Forum Veteran
Sun Mar 14, 2010 6:02 am
Many distributors and dealers still have RB600A boards in stock so you can load up on them if you desire.
FWIW The RB800 looks like a great follow up to the RB600A. The only thing that would make me nervous for long term reliability is the CPU fan.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
siscom
Sun Mar 14, 2010 9:31 am
My feelings exactly.
We install these mostly on outdoor AP units and that means we regularly get 45 Deg C temperatures on them - externally.
Moving parts are usually the first to fail and if the RB800 uses a fan for normal operation then I only forsee problems with this.
Rgds,
Mark.
dingsingo
Sun Mar 14, 2010 11:35 am
My feeling, too.
is the fan watch by snmp ? So i can see, the fan is dead.
dingsingo
normis
Mon Mar 15, 2010 8:17 am
It works perfectly without fan. We tested it with a heatsink for more than 24 hours at full load. The temp was higher, but it worked no problem. So if you want, you can replace the fan with some kind of heatsing (the bigger the better).
dingsingo
Mon Mar 15, 2010 1:35 pm
Hi normis,
ok this are good news.
Thx
dingsingo
honzam
Tue Mar 16, 2010 2:43 pm
When you need info or spec...
there is
http://www.routerboard.com/comparison.html
LAN, FTTx, Wireless. ISP operator
chainsawman
Thu Mar 18, 2010 3:04 pm
You tested the Rb800 on temperature of your country, right?
Here where we installed RBs, the temperature ranges from 30 to 47°C.
Are you sure that without the cooler, even installing a larger heatsink, will still work considering a box with no ventilation?
normis
Thu Mar 18, 2010 3:07 pm
normis
Thu Mar 18, 2010 3:12 pm
sorry we have not tested in such harsh environment specifically with no fan. you will have to test. in any case, ANY hardware should have some cooling mechanism at +40C :?
chainsawman
Thu Mar 18, 2010 4:16 pm
RB600A:
-20°C to +65°C
RB800
-75℃ to +65℃
Considering the specifications, the temperature range for my case will be the same.
And the RB600 has worked very well.
But using logic, to use a higher processor clock, the rb800 hotter than the 600A. You can confirm this?
PS: the RB600 reappeared in the list of routerboard.com :lol:
normis
Fri Mar 19, 2010 8:04 am
The RB800 is very tough temperature wise, as you posted yourself. Those temperature ranges are not just theoretical values, we have a temperature chamber where we actually test the boards with data running, at those temperatures. RB800 is the thoughest of them all. But, we tested with the cooler on, so hard to say the Max without the cooler.
boretto
Mon Apr 05, 2010 11:10 am
It would be great mikrotik sell replacements for this cooler as a spare part
jcrites2008
Mon Apr 12, 2010 10:35 pm
I'm not exactly sure how the RB800 can be a replacement for the RB600 when it costs twice as much!! Those things had better come down in price big time if RB600's really do go EOL. You have any info on this Normis?
Thanks,
Jason
rmichael
Forum Veteran
Forum Veteran
Mon Apr 12, 2010 10:42 pm
Thanks,
Jason
If RB1100 is to be $380 - case - switch chip - bypass - psu - cost of assembly, shipping and extra QC = RB800 for $250...I think :)
jcrites2008
Tue Apr 13, 2010 12:20 am
Only problem is, RB800 costs almost $350. Whereas the rb600 can be had for less than $200.
jcrites2008
Thu Apr 22, 2010 12:47 am
Is there any chance the price will go down on the RB800 now that the RB600 is pretty much out of stock everywhere?
Users browsing this forum: No registered users and 17 guests
