danletkeman
411AH 4.9 Upgrade Problems
Sun May 16, 2010 7:06 pm
Is anyone else having problems after upgrading to 4.9? I cannot seem to upgrade the firmware on the board using the /system routerboard upgrade command anymore.
And I have the board set to run at 800mhz, but in winbox is only shows 680???
dnyl
Re: 411AH 4.9 Upgrade Problems
Mon May 17, 2010 2:11 am
We have the same problem on 433AH after upgrade to 4.9 ROS. The upgrade bootloader is 2.26, but it isn't upgradable. When I update and reboot than the current bootloader is 2.25. Is it a bug?
sergejs
Mon May 17, 2010 3:24 pm
Set /system routerboard settigs set force-backup-bouuter=no
Try to upgrade your RouterBOARD version then.
danletkeman
Sat May 29, 2010 5:04 pm
Thanks, that worked.
Dan.
Users browsing this forum: No registered users and 38 guests
