There seems to be a deference between ntp package client and default ntp client. So if you don't need ntp server feature uninstall ntp package and see if you can sync-up.Make sure you NTP servers actually work, I picked some public ones which worked, but for some reason MK didn't like them and it wouldnt update the time. So if it doesn't work, try some more.
