rmichael
Forum Veteran
Forum Veteran
Miserable 3des ipsec performance on RB750
Fri Jun 25, 2010 2:24 am
PC1---RB750-[ipsec 3des]-RB750--PC2
PC1 to PC2, 1500bytes, udp, 3des ipsec traffic, one way:
65% CPU @ 100kbps
94% CPU @ 150kbps
(ROS4.9)
EDIT: same (lack of) performance on v4.10
meno
Re: Miserable 3des ipsec performance on RB750
Fri Jun 25, 2010 5:16 am
try to connect PC1 to ether1 and the rest to ether2-5
do not use pc1 to pc2 using ether2-5...
I tested normal internet routing upto 40Mbps with rb750
rmichael
Forum Veteran
Forum Veteran
Fri Jun 25, 2010 6:30 am
Hi meno. I think you might have misunderstood as I took a few shortcuts in my diagram. I'm testing throughput over ipsec tunnel between two RB750. Both with factory setup (eth 1 wan, eth2-5 switchport1), firewall disabled. Here's detailed setup:
PC_1 running btest----[eth5]RB750_A[eth1]---{ipsec tunner established}---[eth1]RB750_B[eth5]----PC_2 running btest
I'm getting abysmal 150kbps (that's bits per second!) throughput at >90% CPU utilization.
meno
Fri Jun 25, 2010 7:01 am
I got u.. it will be poor.. these chip are made for SOHO router but its amplified by RouterOS.. if u want good performance buy at lease RB450G or RB1000 it has ipsec hardware acelerator
roadracer96
Forum Veteran
Forum Veteran
Fri Jun 25, 2010 8:03 am
FWIW, I have 1 customer w/ RB450Gs at each site with 3des IPSEC over a T1 at each end. Itll saturate the T1 and not max the CPU. IIRC, it was at ~30-40% cpu?
rmichael
Forum Veteran
Forum Veteran
Fri Jun 25, 2010 8:09 am
Thanks. I've seen other posts quoting 4Mbps of VPN throughput for RB450G so that sounds about right.
rmichael
Forum Veteran
Forum Veteran
Sun Jun 27, 2010 1:01 am
Turns out RB750 has issues with port 1. IPSec throughput on other ports is quite good.
Swordforthelord
Sun Jul 17, 2011 9:31 am
Where did you get this information about Port 1 on the RB750? I have an older one with IPSEC latency issues.
Users browsing this forum: No registered users and 24 guests
