jowi007
r52HN
Thu Jul 01, 2010 6:16 pm
did anyone faced overheating with R52Hn cards ?
i am facing it with some 50 % of them any clue ?
missinlnk
Re: r52HN
Thu Jul 01, 2010 7:06 pm
So far we personally haven't seen any issues from RMAs, but not enough time has passed yet for any problems to show up from our stock.
How are you installing them? Are you putting them in 411, 433/493, or 800 style boards? If in 433/493/800, how many cards per board are you installing? Do you see the problem cards showing up in all situations or just in unique layouts?
jowi007
Re: r52HN
Mon Jul 05, 2010 6:39 am
The cards make noise when we use nstreme and perfomance gets weak on Bwth test
and some of them just make heat without any settings , problems shows on rb433 will try the overheating ones on other boards , do u know any fimware to apply to the cards if this possible ?
lcrhea25
Re: r52HN
Thu Jul 08, 2010 7:27 pm
I am running this card at 2.4b and have the tx power set to default and it is showing to be running at 21dbm. Shouldn't this card be doing 25dbm?
Larry
jowi007
Re: r52HN
Mon Jul 12, 2010 12:07 am
My issue is solved when i set HW retries to 10 instead of 4 in advanced mode
thnx
Users browsing this forum: ouoam and 36 guests
