krec
RouterOS on Dlink hardware
Sun Aug 01, 2010 11:25 am
Hi everyone.
I have а free hardware by D-link DSL-2640U. Can I reshape that from the routerOS platform ?
normis
Re: RouterOS on Dlink hardware
Sun Aug 01, 2010 9:40 pm
No, RouterOS only works on X86 or RouterBOARD™
krec
Sun Aug 01, 2010 9:48 pm
but why?
d-link has enough platform. And what's the difference between dlink and RouterBOARD platform?
THG
Mon Aug 02, 2010 8:56 am
Completely different hardware, and RouterOS won't fit in the flash memory either.
hedele
Mon Aug 02, 2010 8:58 am
That's like asking "hey why can't windows 7 run on my mobile phone?"
D-link is crap, live with it :)
meno
Mon Aug 02, 2010 5:10 pm
they use the same hardware chip, for example the AR7240, the big difference is the software,,, routeros is more complex, routeboard has 2 chips for boot the OS, the bootloader is stored in a 64k eeeprom and a copy in the nand flash. so basically routerboard boots using a "flash drive"
krec
Mon Aug 02, 2010 7:29 pm
:D I agree with you !
From it I want to reshape that crap pice anther devise )))
icefred
Fri Aug 06, 2010 9:16 am
full agree!
think RouterOS should nearly run only on Routerboards, when there's no special constelation, a old pc is most time more expensive in view of power an place.
And for so hacks where ROS might run on, I think the are not worth the time, cause so D-Links have less power, and small Routerboards are not so expensive (I some times too cheap, for example the capacitor Problem ;-) )
nz_monkey
Sun Aug 08, 2010 8:39 am
RouterBoards are very well priced, so there is no reason to buy inferior products.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
adrianatkins
Long time Member
Long time Member
Mon Aug 09, 2010 1:17 am
RouterOS *could* run on your Dlink, but i doubt you'll pay to get it ported.
Bin the dlink (better ebay it) and buy a RouterBoard.
Don't forget to give me at least a tenner a month, every month
Users browsing this forum: No registered users and 99 guests
