HaQs
Netinstall new ROS on RB without RS232 when ROS is damage?
Sat Aug 21, 2010 7:44 pm
Hi.
Can I flash ROS image on RB with netinstall without using the RS232 to configure boot from ethernet ?
Sometimes Happen to damage when updating the ROS from the WLAN.
Alternatively, is there any option to change RB booting to: once boot from ethernet after boot from NAND? or something like that without RS232?
HaQs
Re: Netinstall new ROS on RB without RS232 when ROS is damag
Tue Aug 24, 2010 9:24 pm
There is no such option?
There is a chance to add this option to ROS bootloader: If the long hold down the reset (10 sec) then RB boot from ethernet
fewi
Tue Aug 24, 2010 9:33 pm
The available options are:
  • ethernet
    flash-boot
    flash-boot-once-then-nand
    nand-if-fail-then-ethernet
    nand-only
    try-ethernet-once-then-nand
roadracer96
Forum Veteran
Forum Veteran
Wed Aug 25, 2010 2:18 am
I normally get it by starting net-install and holding reset while power cycling then it net-boots...
Users browsing this forum: mkx and 19 guests
