wireless12
new base station
Sat Jan 01, 2011 1:59 pm
hii..
i m planning for a new base station in 5.8 GHz n only in one chain. becuase we dont have good Mimo antenna aviable here. for base station. moreover even miktriok dont hav a Mimo package as like RB711, it only have a/n single chain, so we dont have good Mimo Cpe package for clients.
so we decided to go with RB711A-5Hn-M for base station with regular 5.8 sector antenna and RB711-5Hn-M for client CPE with regular 5.8 panel antenna.
we are planning to use NV2, or should be use only 5.8 GHz only n (no NV2).?
will it work, will it be stable. ?
will it be more relaible and more powerful then regular 5.8 base station. ?
plz suggest.
Regards.
Belyivulk
Re: new base station
Sun Jan 02, 2011 6:05 am
NV2 is still in Beta - if you will use all MT CPE - then just use Nstream until NV2 is stable :) It will work very well.
wireless12
Fri Jan 07, 2011 3:41 pm
thanks for response
in what manner i should configure my AP (WDS-, Nstreame-settings etc,) and what settings i need in mikrotik CPE ? to get best results...
thx, i would really appreciate comments and suggestion from gurus.
normis
Fri Jan 07, 2011 3:43 pm
Users browsing this forum: rmozoster and 33 guests
