MUM Europe 2020
smurphy
RB493AH, and broken ether1 port ?
Fri Jan 14, 2011 9:53 pm
Hi Folks ...
just wanted to know if someone experienced the same.
While being on travel, my home connection went down. When back - everything seemed OK - however internet connectivity was not possible. Apparently for the Router itself, everything was Ok, however a DSL Connection was not to be brought up.
Only when I moved the connection to another physical port - could the router dial out again (DSL).
Actually - it's the ether1 Port - Power over Ethernet capable one that failed.
Just thinking if I replace the router alltogether or not ...
Thx for any comments.
Ibersystems
Re: RB493AH, and broken ether1 port ?
Sun Jan 16, 2011 11:21 pm
Same issue here but mine installed outdoors.
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
Users browsing this forum: No registered users and 12 guests
