martini
RB1200 more information
Tue Mar 15, 2011 5:50 pm
1 - One core or Dual core system ?
2 - XFP, CX4, SFP or only 10GBASE-T
3 - routing performance ? pps performance.
4 - maybe TCAM for hardware firewall or routing ?? )
5 - price ???
normis
Re: RB1200 more information
Wed Mar 16, 2011 8:24 am
martini
Wed Mar 16, 2011 1:15 pm
yes, i see this file , but didnt find answers fo my questions 1, 3, 4, 5
normis
Wed Mar 16, 2011 1:31 pm
specifications and tests are not published yet.
GuJack20
Trainer
Trainer
Thu Mar 17, 2011 5:58 pm
There will be no SFP ports on HighEnd Routerboards for the near future... this is what i got from this MUM
--Do you remember that guy who gave up? Neither does anybody else!
nz_monkey
Thu Mar 17, 2011 11:30 pm
I suspect you may be proven wrong
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
nawshad
Trainer
Trainer
Thu Apr 28, 2011 12:43 pm
SFP port is more required interface for high end core router.
Nawshad Ahmed
Bijoy Online Ltd.
Nawshad Ahmed
MikroTik Certified Trainer & Consultant
MTCINE,MTCRE,MTCNA,MTCTCE,MTCWE,MTCUME
Cell:+17812610808
Massachusetts, U.S.A
Skype:ahmednawshad
normis
Thu Apr 28, 2011 12:48 pm
once again:
1 - One core or Dual core system ? -> one core
2 - XFP, CX4, SFP or only 10GBASE-T -> only ten one gigabit ports, not 10G!
3 - routing performance ? pps performance. -> published here http://www.routerboard.com/pdf/routerbo ... _tests.pdf
4 - maybe TCAM for hardware firewall or routing ?? ) -> no
5 - price ??? -> cheapest of our rackmount routers. as the presentation mentions, this will be a LOW COST simple rackmount
I think you completely misunderstood the product
Hammy
Forum Veteran
Forum Veteran
Sat Apr 30, 2011 5:43 am
I understand the confusion on the port speed. The published information implied each port was capable of 10GigE, but thinking about a new low cost router having 10GigE ports seems kinda silly.
That said, what's the MTU?
Mike Hammett
The Brothers WISP
miahac
Long time Member
Long time Member
Sun May 01, 2011 8:15 pm
Oh, I assumed the 1200 would be higer performance than the 1100 series.
Network Administrator
Kansas Hosting and Wichita Data Centers
miahac
Long time Member
Long time Member
Sun May 01, 2011 8:27 pm
Looking your benchmarks, I think a couple of common scenarios should be tested.
Firewall On, Connection Tracking On, Masquerading (routing)
EOiP over PPtP with various encryption settings.
winet
Tue May 31, 2011 11:50 am
and how big the data storage size is?
normis
Tue May 31, 2011 11:51 am
like other routerboards, 64MB
winet
Tue May 31, 2011 11:54 am
ow shoot... can't install the dude server on it then, the storage won't be enough
normis
Tue May 31, 2011 11:56 am
RB1200 is low cost version with less features. For more features you need RB1100AH
miahac
Long time Member
Long time Member
Fri Sep 09, 2011 8:40 pm
No metarouter on RB 1200?
normis
Mon Sep 12, 2011 8:22 am
Due to CPU incompatibility, there is no metarouter for RB1200
faisan98
Wed Apr 05, 2017 7:00 am
Hello, I have a issue with RB1200, the RB desconect all user from hotspot, I did upgrade/downgrade too, check the configuration but the issue continue
user connect using hotspot web page, after 5 minutes internet services down and clients can't use internet, all clients out and atfer 5 or 10 minutes they can connect again
the issue continue.
my rb1200 have 1gb ddr2 memory
I think the issue is with configuration, but I copied the configuration in RB450 and RB450 work without issue
what can I do?
faisan98
Wed Apr 05, 2017 7:01 am
Hello, I have a issue with RB1200, the RB desconect all user from hotpots, I did upgrade/downgrade too, check the configuration but the issue continue
user connect using hotpots web page, after 5 minutes internet services down and clients can't use internet, all clients out and after 5 or 10 minutes they can connect again
the issue continue.
what can I do?
Hammy
Forum Veteran
Forum Veteran
Wed Apr 05, 2017 2:23 pm
the issue continue.
what can I do?
You can start a new thread, specific to your problem.
Mike Hammett
The Brothers WISP
faisan98
Thu Apr 06, 2017 2:33 am
the issue continue.
what can I do?
Done, thanks
Lakis
Forum Veteran
Forum Veteran
Thu Apr 06, 2017 1:29 pm
why RB1100AH no SFP+?
jarda
Thu Apr 06, 2017 5:00 pm
It is old device. Ahx2 is current and also quite old while ahx4 is ready to come in near future. You can get sfp+ on other more powerful devices....
Lakis
Forum Veteran
Forum Veteran
Fri Apr 07, 2017 12:44 pm
my mistake I meant RB1100Ahx4?
jarda
Fri Apr 07, 2017 2:01 pm
So what is the relationship to rb1200? Move yourself to the right topic...
Users browsing this forum: MSN [Bot] and 25 guests
