THG
RB751 external antenna
Tue Apr 05, 2011 9:30 pm
Will MikroTik sell external antennas for RB751, or is that something I have to buy somewhere else? Can I use this Cisco AIR-ANT3351? What I need to know is how many MMCX connector RB751 has.
THG
Re: RB751 external antenna
Mon Apr 11, 2011 4:40 pm
Never mind, I purchased one and find out by myself. :)
ronniee
Wed Oct 05, 2011 1:36 pm
the normal MMCX pigtail can't fit in the RB751 :(
what kind of antena can stay there? or is only a joke
normis
Wed Oct 05, 2011 1:37 pm
Only antenna with straight MMCX fill fit easily out of the box: http://www.google.lv/search?gcx=c&ix=c2 ... 6&bih=1071
zervan
Tue Oct 25, 2011 6:30 pm
Sorry for a little bit stupid question, but - do I need MMCX male (http://www.ebay.ie/itm/SMA-male-plug-MM ... 0680271717) or MMCX female (http://www.ebay.ie/itm/SMA-male-plug-MM ... 0604128566) adapter? It is so small that I'm not sure, but it seems that RB751 has female and I need male, right?
Dusan Zervan from Slovakia
MTCNA, MTCRE
zervan
Tue Oct 25, 2011 7:41 pm
It seems that neither of them will help me - I need "female RP-SMA to MMCX" to connect chosen antenna (http://www.dealextreme.com/p/2-4ghz-11d ... enna-47783), which I cannot find :( There are only cables (pigtails), not adapters and I'd like to connect antenna without any cable. Perhaps I have to find an antenna with SMA (not reversed RP-SMA) connector :?
MTCNA, MTCRE
zervan
Tue Oct 25, 2011 8:04 pm
MTCNA, MTCRE
janisbvp
Mon Nov 07, 2011 10:01 pm
This is the reason, why i didn't replace my tp-link 1043 with rb751.
I bought 751, tested and sold it away.
Although it is the same chipset, but tp-link is less professional but more usable.
InoX
Tue Nov 08, 2011 1:03 am
The same for me, I keep my Tplink for now. MMCX antenna is the most useless thing.
scampbell
Trainer
Trainer
Thu Mar 22, 2012 1:18 am
Are Mikrotik going to stock this so we can buy it with our RB751's ?
normis
Thu Mar 22, 2012 10:01 am
RB751G and RB751U now have extended MMCX connector, so no special antenna is needed.
jacobalberty
Thu Mar 22, 2012 7:43 pm
What about those of us with an older model 751u, is there a solution for us to have an antenna?
scampbell
Trainer
Trainer
Fri Mar 23, 2012 6:34 am
That is good news but it would still be nice if Mikrotik carried an aerial we could buy.
I have fitted AC/SWIM to an RB751 but it is a bit ugly :-)
janisbvp
Sat Mar 31, 2012 2:19 pm
...and I thought that an antenna with mmcx connector should be considered "special"...
Most of antennas are rp-sma..
Well, I guess, rb751 internal antennas are enough if it wasn't for rather odd config possibilities in wireless config (antenna a, b rx-a/tx-b) - what is that?
At the MUM Poland I saw a Chinese company, selling nice metal case for rb751 with rp-sma antenna - now thet was cute!
Anyway - after extensive testing it seems to me that internal antennas are enough for a small to medium size house and by placing you router smartly, you can get a good signal and some 20 mbits just about anywhere in the house. Do not consider wireless as a cable replacement, though.
TheWiFiGuy
Sat Mar 31, 2012 9:54 pm
I saw that as well, but seeing as you cant disable chain 0 on the internal, i wasnt sure if the metal case would really screw up performance. Minimum order is 40pcs so waiting for a trial case to turn up. Will report how it goes.
Mikrotik Consultant.
MTCNA, MTWCE, MTCTCE, MTCRE, MTCINE
honzam
Tue Jun 12, 2012 5:36 pm
Hello.
I need mmcx antena for rb751G-2HnD
Is there any antena as MikroTik original accessories?
I do NOT want to connect pigtail MMCX - RSMA and then the antenna. It is unsightly and impractical.
There is no external MMCX antenna? Thanks
LAN, FTTx, Wireless. ISP operator
matiaszon
Mon Jan 21, 2013 1:48 am
Do you remember the name of the company or something? I'm looking for a black (doesn't have to be metal, can be plastic) case for RB751...
srijit92
Thu May 02, 2013 11:10 am
What is the range of Wireless for RB751G-2HnD and RB951G-2HnD ?
Is it sufficient for a 800 sq feet apartment ?
normis
Thu May 02, 2013 11:11 am
Yes, is more than sufficient. Depending on thickness and material of walls, even much bigger house can be covered.
srijit92
Thu May 02, 2013 11:13 am
Ohh thanks alot. Actually I was really confused which one should I buy. One had 2X2 MIMO and another had good amount of RAM and CPU.
Which one do you suggest?
normis
Thu May 02, 2013 11:19 am
RB951-2n is cheaper and smaller, has weaker wireless transmitter, and no Gigabit ports.
RB951G-2HnD is a little bigger, has better antennas, stonger transmitter and Gigabit ports.
RB751U and RB751G are older models. One has gigabit ports, other one doesn't.
srijit92
Thu May 02, 2013 11:22 am
Thanks! Will get a RB951G-2HnD soon.. :)
Users browsing this forum: No registered users and 30 guests
