MUM Europe 2020
artie11
RB435G Case
Wed May 04, 2011 9:03 am
Has anyone worked out what cases they'll be using for the RB435G?
Will end up having to get a misc case and modify it, from the looks
normis
Re: RB435G Case
Thu May 05, 2011 9:58 am
any outdoor case will fit it. why do you need to modify anything?
if you are talking about indoor, why do you need 5 sectors indoors :) ?
nawas
Re: RB435G Case
Mon Sep 12, 2011 2:11 pm
"any outdoor case will fit it" !!!
when you use the Mikrotik large outdoor case i think you need to use some extra "nuts and bolts" to find a space under the RB to use the extra 2 Minipci slot on it , its littlebet difficult but you should try it. :?
normis
Re: RB435G Case
Mon Sep 12, 2011 2:24 pm
is it a problem that you need to use longer distancers under the board? this is to be expected.
AIVAS
Re: RB435G Case
Fri Jan 20, 2012 7:43 am
Well, some of us don't necessarily use all mini-pci slots, but prefer sockets incase one more more dies. I wanted the Micro-SD slot and the USB slots myself. :)
I did find this on a google search though...
http://www.i4wifi.eu/indoor-case-for-rb435g_d2537.html
Might be useful if you don't like putting Routerboards on the pole at a 4 sector 1 uplink site.
Apologies if the thread is a bit old. :)
Users browsing this forum: No registered users and 28 guests
