MUM Europe 2020
mahestic
105 no buffer space available
Sun May 08, 2011 7:45 am
what is 105 no buffer space available.
i have X86 Router .
help PLZ
fewi
Re: 105 no buffer space available
Sun May 08, 2011 6:27 pm
You are giving way too little information. Where did you come across that message? What version are you running? And so on. The more information you give the more likely it is that someone knows an answer.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
Sanity
Sun May 08, 2011 9:32 pm
It is an error message.
;) Sorry, this is the smartest answer anyone can provide without actually even knowing any more context. it also is technically correct ;) And totally useless as an answer ;)
kirshteins
Mon May 09, 2011 8:38 am
This message means that there are too many packets in queue for interface to transmit.
mahestic
Mon May 09, 2011 9:07 am
tanx
babbage
Trainer
Trainer
Sat May 14, 2011 11:03 pm
whats your ROS version?
also do:
/ip route cache print
update us with the output
Users browsing this forum: Google [Bot] and 11 guests
