Hi, I've installed a RB600 bought with 18VDC power supply.
For installation I've used a simple 12VDC battery (solar panel) and POE injector: during day it's correctly working but in the night I loose connection.
I've always worked with RB433.
Checking datasheet it's said RB433 works from 10 to 28 VDC (POA and jack), but about RB600 it's said it works 10 to 56 volts (jack) or 38 to 56 volts (POE).
Anyone can tell me how could my RB work at 13 to 15 VDC from POE?
Maybe isn't a stable power supply, but which is the minimum voltage to make RB600 work from POE?
Thanks.
